Front Brake help please
Old Dec 31, 2025 | 12:25 PM
64Corvette's Avatar
64Corvette
Default Front Brake help please
If it pulls one way is the problem in the opposite wheel?
On my 64 I did a total replacement of all the brake hardware, shoes, rubber lines on all 4 corners plus new brake fluid. It has a slight pull on the front right that I have not been able to eleviate. I talked with a mechanic and he suggested that I needed to replace the left rubber hose. I did but it still pulls to the right. I have the brake adjusting tool that measures the inside diameter of the drum and you then place over the shoes and adjust the shoes to the tool so I feel the shoes are adjusted. Backing up and applying the brakes have not helped. Could it be one of the new wheel cylinders is the problem? I noticed that when replacing the hardware the new the wire rods were painted and seems to be thicker than the old bare wire rods. I sanded the paint off those that seemed to be binding. I am going to go back and check to see if did that on the both front brakes. Any suggestions on how to stop the pulling to the right would be greatly appreciated.
Old Dec 31, 2025 | 12:40 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Did you try swapping front tires? If not, try it. Tire pull is a real thing. It can have one running around replacing brake hardware, brake hoses, cylinders, wheels alignments and suspension parts. Tire pull will look like poorly adjusted brakes or a poor alignment when its the ... tire.
Dan
Old Dec 31, 2025 | 01:05 PM
toddalin's Avatar
toddalin
If you need anything, I still have the drum brake set-up from my '64, though shipping brake parts can be heavy (=$$$).
Old Dec 31, 2025 | 01:08 PM
Whatscooking's Avatar
Whatscooking
Sometime they need time to fit the drum correctly, I would drive it for a bit.
Old Dec 31, 2025 | 01:22 PM
Duck916's Avatar
Duck916
A few questions and comments:
--Does it pull all the time? When the brakes are cold as well as when they are hot?
--Is the pull constant regardless of how hard you're hitting the brakes? Or is it in the initial "bite"?
--Do the shoes show even wear (forward to back shoe and top to bottom of the shoes)?
--Can you drive the car for a bit and then measure the drum temp side to side?
When I adjust drum brakes, I like to get them to the point where the shoes are contacting the drum, then back them off one click. I find that if one side is adjusted closer than the other, the initial bite will cause a pull, but that is transitory as the other side contacts the drum. (I know the adjusters should take care of this, but that doesn't always seem to work).
Old Dec 31, 2025 | 01:54 PM
Whatscooking
If you pull off the drums you can see where the shoes are rubbing and likley the side that is pulling to has more contact aera, it's called arching the shoes to fit. Sand a little off the bottom of the shoe to allow the shoe to lay down and fit better or go for a spirited drive and seat them in. Grease from a rear axel seal leaking on the rear shoes will cuase pulling problems also but likley you need to just seat in the new shoes.
I am assuming you know there is a primary and secondary shoe. Shorter shoe up front putting it pressure on the secondary shoe.
Old Dec 31, 2025 | 05:04 PM
Factoid's Avatar
Factoid
I’ll add that the star adjusters need to go in the correct way or every time you back up and brake, the shoes will loosen. If that happens on one side, you may experience a pull on the other side.
Old Dec 31, 2025 | 08:33 PM
benrep's Avatar
benrep
2025 c1 of the Year - Modified Finalist
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
Another important factor that often is overlooked is drum diameter. If the drums were machined and one is .050 over and the other is just .015, that can cause a pull. I always make sure that all drums are equal when relining drum brakes. Also remember that a rear brake can feel like a front pull sometimes. Does it yank the steering wheel or just pull the car to the side some. If the later it could be a rear brake. Good luck.
Old Dec 31, 2025 | 09:36 PM
R66's Avatar
R66
I would jack up the front, hit the brakes hard, then release them and try to turn them. If one turns harder than the other it may not be releasing. Then try the rear brakes the same way. They will cause a pull under braking.
Old Jan 1, 2026 | 06:28 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
I have seen shoes with friction issues. Try swapping the shoes left and right (leave the springs on the same side) and see if anything changes.
Old Jan 2, 2026 | 12:58 PM
toddalin's Avatar
toddalin
Did you somehow contaminate the pad? See above.
Old Jan 2, 2026 | 01:02 PM
Limp's Avatar
Limp
One click tighter on the left side.. If that helps but not enough, go one click at a time until it stops straight
LIft it with a jack and roll the wheel each time to make sure its not too tight everytime you give it one click of adjustment
Old Jan 4, 2026 | 09:09 PM
BD104X's Avatar
BD104X
Thats what I was going to say. OP could try swapping drums and readjusting.
Old Jan 4, 2026 | 09:21 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
That would actually be a lot easier to try first before swapping the shoes like I had recommended above.
Old Jan 5, 2026 | 01:03 PM
toddalin's Avatar
toddalin
I'm assuming that the drum is still within it's acceptable diameter. IIRC, this is marked on the drum.
To Front Brake help please
