[C2] TI setup question
Old Dec 31, 2025 | 04:32 PM
Michael H's Avatar
Michael H
Default TI setup question
I have a TI setup that I was running in my 63 for years and have gone back to stock.
I had picked this up a long time ago at a swap meet.
Does anyone know what this goes to and value ?
Distriutor has 191 in the casting - no aluminum band with part number
wiring is coming off of amplifier - not a connector right on the amp. No labels on amp.
Coil has 1115207 stamped on it
Old Dec 31, 2025 | 04:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
That is an over the counter GM replacment coil. The Amp box looks the be. 69 on up
Old Dec 31, 2025 | 04:48 PM
Michael H's Avatar
Michael H
thanks - I'll move this to the C3 forum
Old Dec 31, 2025 | 05:12 PM
Nowhere Man
Without a tag I doubt any one can pin point it to a car
Old Jan 1, 2026 | 11:06 AM
TokyoMark's Avatar
TokyoMark
Retired
According to my 1966 judging manual a 1115207 coil is a small block L79 transistor coil.  If it's anything like an original big block ignition coil it's probably worth quite a bit......if it works.
Old Jan 1, 2026 | 11:07 AM
Nowhere Man
It's just an over the counter replacement coil for all TI engines. It's still worth a good bit but not nearly as much as assembly line coils
Old Jan 1, 2026 | 12:10 PM
rich5962's Avatar
rich5962
That may be the Delco1115343 accessories version which could be used on anything 12v back in the 60's. The Amp had a short harness & plug.
Both the TI Contact Controlled and Magnetic Pulse versions came with a 207 TI coil.
Much information on the Delco Accessory TI(CC,MP), CDI, & HEI systems HERE.
Rich
Old Jan 1, 2026 | 03:53 PM
DansYellow66's Avatar
DansYellow66
That’s a pretty interesting website.
Old Jan 1, 2026 | 08:11 PM
Dave Strickland's Avatar
Dave Strickland
Default Coil
It is a service replacement coil but it is an original USA made Delco Remy item. It will judge fairly well if that is required and it will make your TI equiped Corvette run properly. With asking prices for embossed original Delco coils in the $500 to $750 range this coil is a very useable piece.
Old Jan 1, 2026 | 08:14 PM
Nowhere Man
like I said its still worth a good bit. I am glad my dad has one of these in the toolbox as a spare
To TI setup question
