[C2] Squeaky Speedometer
Old Jan 3, 2026 | 03:48 PM
D-FRESH3's Avatar
D-FRESH3
Default Squeaky Speedometer
My 66 has an intermittent, squeaky speedometer. I will be pulling the gauge cluster and lubricating the gears. My question is, has anyone else had this issue, and what do you recommend for lubrication? Also, other than lubrication, is there anything else I should look for as a suspect, while I'm in there? I am also considering changing the speedometer cable while I have things opened. It's very annoying when it happens.
Thank you in advance. Video attached.
Doug
File Type: mov
Old Jan 3, 2026 | 04:21 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I have used liquid graphite before with good luck
