engine Stamp
Old Jan 26, 2026 | 12:50 PM
cjm1229's Avatar
cjm1229
3rd Gear
Default engine Stamp
All thanks in advance for your help. Recently acquired as 63 swc with a non-original engine and am looking to decode and engine casting number and stamp #'s. I am fairly certain the J43 stamp would indicate a casting date of October 4 of 63. What i need help with the second series of number on the engine stamping T007RE.
Please offer any help you can.
Old Jan 26, 2026 | 02:29 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Let's get you to the right place.. welcome
Old Jan 26, 2026 | 02:37 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
1964 327/365 from Corvette vin 102616 assembled on Oct 07 1963 casted on Oct 4 1963 that car it came in was built Oct 12 1963 so it all aligns perfect
Old Jan 26, 2026 | 03:08 PM
Factoid's Avatar
Factoid
If it is still an L76 engine, you got a hot one!
Old Jan 26, 2026 | 03:10 PM
Vet65te's Avatar
Vet65te
cjm - Welcome to the Corvette Forum. You do know that new members are 'required' to post up pics of their Corvettes...right? ;-).
Mike T - Prescott AZ
Old Jan 26, 2026 | 03:15 PM
65hihp's Avatar
65hihp
yes it is the matching engine for 64 L76 02616, and in his rush to be first to reply to your query, someone failed as usual to answer your question. The date stamp of I007RE has a faint F in front of it, obscured by the orange paint.. Alpha font I was used in place of numeral 1 on date stamps from Flint foundry. If you are inclined to, you can remove the orange paint, very carefully, using good paint remover, or lacquer thinner by rubbing with a soft rag. Don't scrape the pad with any tool, other than perhaps a plastic paint scraper.. Use nothing metal on the pad, as you will damage its fine original surface.. You want to preserve the broaching machine marks that are fine as frogs hair.. Here is a similar pad from engine a couple months later than yours..
Old Jan 26, 2026 | 06:40 PM
mikelj's Avatar
mikelj
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
Wow, you have incredible eyes, I see nothing at all in front of that "I" on the suffix stamp. If it is there, somebody poured a huge glob of engine paint on top of it and filled all the stamp indentation completely. That will take a gallon of lacquer thinner to remove. Good luck with that.
Old Jan 26, 2026 | 07:07 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I tend to agree with Mike, I dont see a faint F !
Old Jan 26, 2026 | 07:08 PM
Nowhere Man
after I zoomed in I can see something that looks something like a F. But we all know there is one there
Old Jan 26, 2026 | 07:16 PM
Factoid's Avatar
Factoid
If you blow it up and enhance it a bit, you can see the shadow of an F, but then the E looks like it used to be an F (wouldn’t make sense to change it as RF is the FI engine).
Old Jan 26, 2026 | 08:24 PM
kkupec02's Avatar
kkupec02
Welcome!!
Old Jan 26, 2026 | 09:21 PM
6T7L71CPE's Avatar
6T7L71CPE
This is an inverted image of it:
Old Jan 26, 2026 | 09:54 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I can see the very faint F (increased sharpness), but it's really odd to me that every other character in both stamps is so deep and easily read.
Here are others right around 10/7/63 which all show much more obvious Fs.
Compare the shapes of the two 0s and the R to the 10/09 stamp — they look like great matches to me. Just odd the Fs are so different. (The 10/01 stamp uses the same 0s but reversed positions!)
Old Jan 26, 2026 | 09:57 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
And a bit of fiddling with both the original image and the negative image:
Old Jan 29, 2026 | 03:28 PM
cjm1229's Avatar
cjm1229
3rd Gear
You were correct the F is clearly visible now.
Old Jan 29, 2026 | 04:00 PM
65hihp's Avatar
65hihp
good job removing that paint, without damage to that factory original stamp pad.. That would pass NCRS scrutiny with flying colors.
Old Jan 29, 2026 | 04:30 PM
cjm1229's Avatar
cjm1229
3rd Gear
Thanks for the help. One other item i was looking at was the difference in tachometers that were used in 63. Mine redlines at 7000 others i have seen online redlines at 5500. What is the correlation between tach and engines size and or hp ?
Old Jan 29, 2026 | 05:13 PM
65hihp's Avatar
65hihp
I would suggest a new thread for that question but in general as you might guess, low hp motors with pump up lifters had the low redline tachs, and high hp motors with mech lifters had the high redline tachs. All motors in 1963 Corvettes were 327 ci.
To engine Stamp
