Engine Identification...
Old Jan 28, 2026 | 05:24 PM
dnelson8031's Avatar
dnelson8031
Cruising
Default Engine Identification...
Dear Forum;
I recently purchased a '63 Corvette with the removable hard Top.
I've been messing with Cars for the last 60-ish years but, have never had to question their Engines.
All of the '63 Corvettes that I have looked at have had their Alternator on the right side of the Engine.
My '63 has it on the left side. What does this mean?
The Engine code is 9875954 GM1. I am a novice when it comes to 'reading' this code
Would someone be able to help an old guy?
David Nelson.
Old Jan 28, 2026 | 05:30 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Where did you get that number? Have you looked at the stamp pad on the right front of the block just below the head. Dennis
Old Jan 28, 2026 | 05:38 PM
dnelson8031
Cruising
Ah ha.... This #was on the left rear on the Block.
I'll go look at the right front like you have suggested.
Thank you...
Old Jan 28, 2026 | 05:43 PM
gbvette62's Avatar
gbvette62
Where did you find what you're referring to as the "Engine code is 9875954"? While it looks like a Chevrolet casting number I'm not aware of any seven digit casting numbers that start with "9", they usually start with a "3". If it was on the left rear of the block it is the casting number, but you need to recheck it. The correct casting number for a 63 327 is 3782870.
On the right front of the block, just forward of the right side cylinder head is a machined pad that should have two sets of numbers/letters stamped into it. One is the engine code which will include a letter for the engine plant, four numbers for the month and day of assembly and one, two or three letters to identify what the engine is. The second set of numbers is a VIN derivative that should match your car's VIN.
Old Jan 28, 2026 | 05:47 PM
vark_wso's Avatar
vark_wso
Originally Posted by dnelson8031
Dear Forum;
David Nelson.
David
Perhaps you provided the casting number from the top of intake manifold instead of the engine block casting number? If so perhaps the first digit is a "3" -- not a "9"? If so, that's common Chevelle, Chevy II, etc quadrajet intake for late 60's metal car. The "GM1" would be the mold number used for that casting (batch) likely from the Saginaw Grey Iron or Tonawanda foundry.
Old Jan 28, 2026 | 06:05 PM
dnelson8031
Cruising
Thank you.
I'll go look
Old Jan 28, 2026 | 06:21 PM
jforb's Avatar
jforb
yeah, the intake casting number won't tell you a whole lot about the rest of the engine!
The block will have it's casting number on the top left rear (top of the bellhousing), and the casting date either nearby, or on the other side of the top of the bellhousing area. The casting date code will be a letter followed by 1 to 4 numbers, the last one is the last digit of the year.
The stamped numbers and letters on the pass side top of the block, just in front of the head, are most informative (if they are there).
Pictures help a lot.
fwiw, most Chevy engines had the alternator or generator on the driver side through 1968, and switched to the pass side in 69...but Corvettes were different, of course.
Old Jan 28, 2026 | 06:37 PM
begee22's Avatar
begee22
From: Edmonds Washington (Stunning view of Olympic Mtns and Puget Sound)
Dear Forum;
David Nelson.
As to the alternator mounted on LS.........that would mean a car in '63 with AC compressor mounted on RS. Being a roadster and rarity of AC (274 built) its highly unlikely the original motor. Does center dash above radio have AC vent? More engine data should be provided to determine what you have. begee22
Old Jan 29, 2026 | 07:26 AM
morly1963's Avatar
morly1963
Following
Old Jan 29, 2026 | 10:48 AM
dnelson8031
Cruising
Thank you....
Old Jan 29, 2026 | 10:56 AM
lucky131969's Avatar
lucky131969
Thank you....
Pictures speak volumes.
To Engine Identification...
