[C1] Steering Third Arm / Pitman Arm Ball Stud
Old Feb 19, 2026 | 12:17 PM
tstans's Avatar
tstans
Cruising
Default Steering Third Arm / Pitman Arm Ball Stud
Does anyone know the correct way to install new Steering Third Arm / Pitman Arm Ball Studs. The new ones I purchased did not come with any instructions.
Old Feb 19, 2026 | 07:17 PM
Pilot Dan's Avatar
Pilot Dan
Remove the old stud being careful not to enlarge the hole. Insert new stud and peen it over similarly to the old one. Heating it will make it easier to upset. I then add a few welds for good measure.
Old Feb 21, 2026 | 11:59 AM
tstans's Avatar
tstans
Cruising
Thanks San,
I was headed that direction. Wondering if anyone had used a air chisel or something like that for peening it over.
Old Feb 21, 2026 | 05:14 PM
Pilot Dan's Avatar
Pilot Dan
You could do that as long as the stud is properly supported and protected from deforming.
To Steering Third Arm / Pitman Arm Ball Stud
