[C2] Possible heater core replacement
Old Apr 1, 2026 | 11:32 AM
rfkirk's Avatar
rfkirk
Default Possible heater core replacement
I am considering purchasing a 1967 Corvette with factory air and a big block 427. The previous owner (not available) had disconnected the heater hose from the block and zip tied them out of the way. I suspect that he had a leaking heater core and this was his quick fix. Of course, it could be that the hot water valve stuck open and he just had too much heat in the passenger compartment and this was his way of dealing with it,
I am fairly proficient DIY guy with plenty of tools, I have installed two Vintage Air AC systems in cars that I have resurrected (I live in Texas) and I have replaced a heater core in an old Jeep Wrangler that entailed removing the steering wheel and dash (what a PITA) . However, it appears that the big block takes up a lot of free space to get at the engine side of the heater box. How involved is this going to be if I have to replace the heater core?
Old Apr 1, 2026 | 11:36 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
I'm no help but will give you a bump to the top. But if I lived in Texas, I would do it when it was cool. Good luck!
Old Apr 1, 2026 | 11:41 AM
633BR's Avatar
633BR
It should be in your wheelhouse, I know you have to remove the glove box and other interior parts to get to it with the most difficult part under the dash working in a contorted position. I'm not a great mechanic, but I could get it done in a weekend. If it's the car I think it is, it's worth the effort.
Old Apr 1, 2026 | 11:43 AM
rfkirk's Avatar
rfkirk
I made the job a shade easier on all the cars by removing the passenger seat. It makes being a contortionist a shade easier.
Old Apr 1, 2026 | 11:58 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
First get a copy of the AIM and you will see they built the car around the heater core. The hardest part is separating the inner and outer without breaking anything.
Old Apr 1, 2026 | 12:02 PM
rfkirk's Avatar
rfkirk
Yeah, I once had to replace the fuel tank on a 1969 Jaguar XKE (E-Type) and I swore that tjhe first component placed on the assembly line was the damn tank and that they built the car around it with less than 1/4" clearance on any side........what a nightmare.
To Possible heater core replacement
