1963 E brake light
Old Today | 08:26 PM
Mitch03Z06's Avatar
Mitch03Z06
Default 1963 E brake light
On my 63 I refurbished my cluster. I am not sure if the E brake light worked before I started the refurbish process. I replaced all of the bulbs, gages, and made sure the tech and speedo worked. After installing the cluster I noticed the E brake light stays on. I remove the wires from the switch and it went out. I then removed the switch and checked its function. When you push the plunger continuity is broken, so the switch works. What on the E brake rod trips the switch, is there a screw located on the rod that’s trips it. Any help is appreciated. Thanks, Mitch
Old Today | 09:24 PM
65GGvert's Avatar
65GGvert
There's a stop pin that goes into the shaft that pushes open the switch when parking brake is off.
