66 idling problem
I think I got the distributor back in the same position. I noted the position of the rotor when I took it apart and tried to put back in the same position. Is it possible i got it very close and but not exactly where it was? I didn't move the engine at all. It seemed to me that the ditributor would only go back in where I wanted it or noticeably different than where it was. Could i have gotten it off just a wee bit and thrown the timing off. I did re-time the car after getting everything together. It is just that the car acts like it did when I got it and then the timing was way to advanced. I have it set about 10* ahead right now. (327/300) After taking off It runs great almost instant acceleration. But it does not idle just right. You need to rev it a little to even let off the clutch or it wants to die right down. Before when I set the timing to 10* it would idle great and but seemed like it had just a little acceleration lag at low RPM. NOw it is at 10* and acts like it is advanced. Could I have been just a little off when putting back the distributor? And if so does anyone have a tip on the best way to get it set properly?
THe other change I made while the engine was apart was with the carb. Before I had a oil fill tube that was broken at the PCV connection. SO the carb line was cut off and plugged. I replace the fill tube and put on a new line to the carb. Could this have thrown off my carb adjustment and caused the same problem? Doesn't seem right to me.
I think it is more likely the timing. Just hoping someone could give me a good way to check.
[Modified by tl-vette, 11:29 PM 3/8/2003]
Is the PCV system properly configured for your engine IAW the application shop manual or AIM?
Duke
[Modified by SWCDuke, 10:55 PM 3/8/2003]
I drove the car yesterday after putting everything back to gether and the oil leak was fixed. Drove it twice as a matter of fact while messing with the idle.
Then I take it out today and it starts leaking like crazy at the back of the intake still. I used a silicone RTV with the seals. Did I not let the silicone set up long enough? The front seal didn't leak. It is hard to tell if the rear one moved on my when I tightened the manifold down. (30ft/lbs) Did I not use enough silicone? It was pushing out the sides a little. Didn't want to put so much it went way insode the engine. I took it all back apart tonight and pull out all the gaskets and seals. i am going to get another set and start over. It was cold in my garage. Think I should have waited longer after sticking the seals down to the block. The silicone seemed to stick to the manifold and block but not to the rubber seals. Should I have used another type of silicone? I used the black automotive RTV. I could sure use some help. I have an aluminum manifold (65 serial number) I would hate to go thru this all again. :mad
TL
