Power valve question
Old Apr 16, 2003 | 01:16 PM
67opentop's Avatar
67opentop
5th Gear
Default Power valve question
I' ve got a 427/390 (Holley carb) '67 w/43K orginial miles.
It backfires through the carb around 4,000 (unless I ease the throttle up to that level).
Keeps blowing out the power valve.
Timing and dwell are set right.
I have not rebuilt the distributor but I did have the carb professionally rebuilt. Problem exixted prior to that rebuild.
Any ideas?
Thanks,
:banghead:
Old Apr 16, 2003 | 09:27 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Power valve question (67opentop)
sounds like the cam lobe is going away :chevy
Old Apr 16, 2003 | 09:29 PM
Kid_Again's Avatar
Kid_Again
...what is the condition of the plugs?
...what's the carb numbers on the air horn?
...DON'T tell me you're running a double pumper, it's a boat anchor unless you have one bad butt engine
edit...oops, missed the point that the problem existed before the carb rebuild..., agree that you need to check the timing (need to use a vacuum can) and the basics first...what are your timing specs and btw, when did you first notice this problem and what was the occurence associated with?
[Modified by Kid_Again, 7:07 AM 4/17/2003]
Old Apr 17, 2003 | 03:57 AM
ghostrider20's Avatar
ghostrider20
Default Re: Power valve question (Kid_Again)
This sounds like a timing issue. Are you sure the timing is set up right?
I had a High RPM miss that was due to a faulty alternator at high revs. The car would pop, miss and backfire at 5000 RPM like clock work. Alt. rebuilt cured it.
Mark
[Modified by ghostrider20, 3:01 AM 4/17/2003]
Old Apr 17, 2003 | 08:53 AM
MasterDave's Avatar
MasterDave
Moderator
Sounds like an intake valve hanging up to me. If it happened before the carb rebuild and after, it prolly isn't the carb. :chevy
To Power valve question
