Does this look any better?
Apr 16, 2003 | 06:51 PM
St. Jude Contributor '03 & '04
My frame to start:
After replacing all parts behind crossmember #3, straightening, sandblasting, and painting (thanks, Gary Taylor, for some critical frame measurements):
And my 327 just back from the machine shop:
[Modified by gary6696, 11:57 PM 4/16/2003]
Apr 17, 2003 | 11:25 AM
St. Jude Donor '09
Re: Does this look any better? (gary6696)
:thumbs:
What did you use for Paint?
Apr 17, 2003 | 11:32 AM
Re: Does this look any better? (96TorchRedCoupe)
Gary
I have almost the exact same pictures of the frame on my 66 coupe. Yours looks great! I painted mine black Imron.
[Modified by 4WDVETTE, 11:33 AM 4/17/2003]
Apr 17, 2003 | 12:09 PM
Looking good, keep the progress pictures comming. :cheers:
Apr 17, 2003 | 01:30 PM
Re: Does this look any better? (Tom/99)
:cool:
Apr 17, 2003 | 02:19 PM
Re: Does this look any better? (kyosho)
Progress !:smash: :jester
Apr 17, 2003 | 03:25 PM
Gary,
Looking good! When does reassembly start?
Did you do anything to the inside of the frame?
brian
Gary,
They both look great. :cheers:
What did you use and how did you paint the frame?
GaryC
Apr 17, 2003 | 03:37 PM
Re: Does this look any better? (GaryC)
Thanks for the compliments.
Frame paint: Transtar self-etching primer, then BPS low-gloss black tractor enamel. I sprayed both with an HVLP gun. Inside the rails I sprayed a zinc based self-sacrificing primer out of rattle cans.
Re-assembly starts as soon as I get my T arms and A arms back.
Apr 17, 2003 | 04:42 PM
How did your block come out? What did they have to machine? How are you going to set it up?
Sounds like the fun parts just about to get started.
allcoupedup
Apr 17, 2003 | 06:25 PM
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
Re: Does this look any better? (Allcoupedup)
Looks Great ! :thumbs: Can't wait to see the finished product.
:cheers:
Apr 17, 2003 | 07:25 PM
"How did your block come out? What did they have to machine? How are you going to set it up?"
Bore .030 (1st bore), crank .010, rods .005, line bored and balanced.
It will be back to stock 300 hp. That's enough for an old man. ;)
