Torque Spec Sheet.....A Complete Listing..?????
Can I expect to find a complete easy to find listing of all the bolt torque specs? :cheers:
Its all over the AIM and Service Manuals. Ya gotta work at it to get a list or spend time thrashing through the books with dirty fingers to find the diff yoke torque for a BB or the rear spindle nut torque. I kinda like the front wheel bearing torque spec too. The chart in the back of the Service Manual is only the beginning. :nopity
[Modified by magicv8, 12:50 PM 4/17/2003]
Gotta remember..................It's a Mid Year..... :jester
[Modified by Viet Nam Vett, 7:14 PM 4/17/2003]
...just call me over the weekend and i'll give you the specs you need if you don't the docs available......OR, you can use the method that my roadster's previous owner used => tighten until the bolt breaks and then back off one quarter turn
________________________________________ _______________________
Who's The Doc............?????
Well I found the torque....Y specs in the AIM ...I should be out their wal-ering around on the cold cement floor if you want to stop by for a beer or a hand.. The house looks like the shipping dept at LI Corvette.. Parts all over the dinning room table...rear diff on the kitchen floor T arms in the floor under the dinning room table.empty boxes and packing gack all over the place.....Man..it's good to be single....And it's good to be the king.... :lol:
here's the address 627 Zion Rd..EHT..I'll IM you the phone number :jester
Thanks for reminding us enslaved masses what true freedom is like...I had almost forgotten! :crazy: :boxing :banghead:
ball joint nut, lower 20 ft lbs
ball joint nut, upper 45 ft lbs
ball joint service bolts 20 ft lbs
brake caliper anchor bolt 75 ft lbs
cam sprocket 20 ft lbs
camber cam, rear strut 65 ft lbs
carrier, fronnt support cross bolts 55+key ft lbs
carrier, fronnt support to cross member 65 ft lbs
clutch housing to engine 30 ft lbs
clutch pressure plate 35 ft lbs
collar bolts 40 ft lbs
connecting rod 50 ft lbs
control arm, lower, front 70 ft lbs
control arm, lower, inner pivot nuts 50 ft lbs
control arm, lower, rear 135 ft lbs
control arm, upper, attach nuts 35 ft lbs
cover, timing chain 80 in lbs
crossmember to frame 25 ft lbs
crossmember to carrier 60 ft lbs
damper (balancer) 85 max ft lbs
distributor clamp 10 ft lbs
flywheel to crank 60 ft lbs
head bolts, sb 65 ft lbs
main bearing caps, sb 80 ft lbs
manifold, exhaust, sb 20 ft lbs
manifold, intake, sb 30 ft lbs
motor mount, front, to chassis 30 ft lbs
motor mount, front, to engine 25 ft lbs
motor mount, rear, to cross member 40 ft lbs
motor mount, rear, to transmission 45 ft lbs
oil filter bypass valve 80 in lbs
oil pan engine, all 80 in lbs
oil pan plug 20 ft lbs
oil pump 65 ft lbs
pitman arm to control valve 120-150 ft lbs
pitman arm to steering box 42-47 ft lbs
rebound bumper to frame 20 ft lbs
shock absorber, front, lower bolt 10 ft lbs
shock absorber, front, upper nut 20 ft lbs
shock absorber, rear, lower nut 35 ft lbs
shock absorber, rear, upper nut 50 ft lbs
spark plug 25 ft lbs
spindle, drive, nut 100+key ft lbs
spindle, drive, to axle drive shaft 75 ft lbs
spring link bolt to torque arm keyhole align
spring retainer bolts, rear 65 ft lbs
stabilizer bar link nuts 10 ft lbs
stabilizer bar to frame 10 ft lbs
stabilizer shaft bracket to arm 120 ft lbs
stabilizer shaft bracket to frame 120 ft lbs
stabilizer shaft link bushings 25 ft lbs
starter special bolts 30-40 ft lbs
steering box cover 25 ft lbs
steering box to frame 30 ft lbs
strut rod bracket to carrier 45 ft lbs
strut rod to spindle support 80+key ft lbs
support, drive spindle, to torque arm 30 ft lbs
torque arm pivot 50+key ft lbs
tramsmission to clutch housing 50 ft lbs
universal joint, driveshaft and sb 15 ft lbs
universal joint,bb axle 25 ft lbs
valve cover 50 in lbs
water outlet 20 ft lbs
water pump 30 ft lbs
wheel stud nuts 60 ft lbs
Paste it into an excel spread sheet
:blueangel:
Thanks for taking the time to type all that out....."Lotsa" work!!! Thankyou.
I will print it out and tape it to the gas tank as I roll around on the cold concrete floor and torque away..... :lol:
Thanks Again.. :flag
thanks again....frank in Colorado
"cold"?????
...it's in the upper 60's today....time to switch to shorts n tees!!!
Not in my Garage/ Meat Locker.............
