rust-bolts
Old Apr 21, 2003 | 11:35 AM
backagain's Avatar
backagain
Default rust-bolts
Just cleaned and polished the intake manifold bolts. Of course a coating of rust appeared pretty quickly. Any ideas as to what to coat these bolts with to protect the surface knowing the heat they are subject to. thanks - george
Old Apr 21, 2003 | 11:44 AM
JohnZ's Avatar
JohnZ
Default Re: rust-bolts (backagain)
What type of bolts are they - zinc-plated or natural (dark phospate & oil) steel? Zinc-plated won't rust (unless you polish off the plating), and clear VHT may keep un-plated natural bolts from rusting if you clean them first with lacquer thinner and apply the coating immediately. Fasteners are coated for a reason, but if you polish off the protective coating, the result is rust. :thumbs:
