Hooker Headers ...installing?
Old May 11, 2003 | 08:03 PM
Drnumnutz's Avatar
Drnumnutz
4th Gear
Default Hooker Headers ...installing?
I am installing headers to side pipes on a 75 stingray.We dropped in a 383 stroker and I uses Hooker headers instead of stock mans.They fit like a glove.Too close to everything.They are 1/2" from the pitman arm rubber grease cover and would surely burn it.Also they rest against the frame and would ignite the under coat.The rubber body trim beneath the fenders is almost in contact with them also.They are the correct parts but I cannot fire up this new engine before we correct these fire hazards. Any suggestions ? :confused:
Old May 12, 2003 | 12:51 PM
JohnZ's Avatar
JohnZ
Default Re: Hooker Headers ...installing? (Drnumnutz)
Good testimonial for sticking with stock exhaust manifolds - headers are a huge PITA (fit, interferences, melted plug wires/boots, noise, loose bolts, blown gaskets, underhood heat, exhaust leaks, ground clearance problems, etc.), and they provide little performance improvement unless the rest of the exhaust system is replaced with very low-restriction components. The stock ram's-horn manifolds are very efficient, and they avoid all those problems. :rolleyes:
