temp guage problem?
Old May 17, 2003 | 02:24 PM
ptuner's Avatar
ptuner
Default temp guage problem?
I have a '60 driver. The problem is the temp guage suddenly reads 220 degrees (way hot) while the engine is still 180 (heat measuring gun). I've changed the sending unit twice and still have the same problem. The guage registers cold when starting but moves to the 220 side within a few minutes. There is still a little room for the guage needle move to the varying temperatures, so it is working; just showing to hot. I've replaced the sending wire with no effect. Must be the guage? Do temp gauges ' go out ' this way? Who fixes temp guages? thanks for all the help now and in the past!
Old May 17, 2003 | 02:59 PM
JoesC5's Avatar
JoesC5
Default Re: temp guage problem? (ptuner)
North Hollywood Speedometer and Clock did repairs to mine. They are located in, where else, North Hollywood, CA Joe
Old May 17, 2003 | 03:12 PM
62fuelie's Avatar
62fuelie
What kind of temp sender do you have? Some of the temp senders are designed to work with idiot lights and are "on-off" rather than linear. Try a Wells TU5 sender from Autozone. About $6. Most everyone (but not all) who has tried these units reports good results.
Old May 17, 2003 | 03:14 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Check the line between the guage and the sending unit. Every once in awhile my guage acts like yours. Sometimes my needle will start a steady rise and just as I'm about to pull over to see what's going on, it drops back to normal. This has also happened well before the car had been fully warmed up. I suspect that there's a break somewhere in the lead that occasionally separates from vibration or possibly a bad connection at the guage. This wouldn't be the first time a 38 year old wire has failed :).
[Modified by Vetterodder, 12:15 PM 5/17/2003]
Old May 17, 2003 | 05:31 PM
62fuelie's Avatar
62fuelie
Default Re: temp guage problem? (Vetterodder)
For test purposes, just run a new wire straight from the gauge to the sender.
Old May 17, 2003 | 10:12 PM
hot1corvette1's Avatar
hot1corvette1
In the latest NCRS Driveline, there is an ad for Lectric Limited who claim to have a line of absolutely correct temp senders. They say they have them calibrated exactly the way the OEM senders were way back when. Who knows, may be worth a try.
Old May 18, 2003 | 01:59 AM
ptuner's Avatar
ptuner
thanks for all the suggestions. I really appreciate the help. :)
To temp guage problem?
