Alignment
Old Jun 1, 2003 | 09:05 AM
6tee6's Avatar
6tee6
Default Alignment
I took the 66 out for its first high speed road test last night. About 30 miles at 75 mph. Everything seemed to check out fine. However, I noticed the front end seemed a little loose. I'm thinking I need to have the alignment checked. Since we only have one shop that does alignments here is there anything I can tell these guys before they start work or are the alignment procedures fairly standard for these things??
(I DO plan to tell them to take off there greasy coveralls before they drive it onto and off the lifts)
Old Jun 1, 2003 | 09:34 AM
kellsdad's Avatar
kellsdad
Default Re: Alignment (6tee6)
Here is a partial list of things that may cause "loose steering":
1. Worn bearings in the steering columun.
2. Worn rag joint.
3. Worn or poorly adjusted steering gear.
4. Worn suspension components.
What makes you think the problem is due to an alignment problem?
Old Jun 1, 2003 | 12:31 PM
JohnZ's Avatar
JohnZ
Default Re: Alignment (kellsdad)
What kind/type/size of tires are you running? What tire pressure? How old are your control arm bushings/ball joints/tie rod ends - any play there? Are the front wheel bearings properly adjusted? A good alignment guy can check those items out in a hurry, as they should do that before they start any alignment procedure anyway.
The front alignment is no different than any other car; the rear toe-in is the tricky part, and takes time. Give us some more info and we can give more guidance. :thumbs:
Old Jun 1, 2003 | 02:32 PM
6tee6's Avatar
6tee6
Good point...
I'm not sure its simply an alignment. It could be any one or all of those things you mentioned.
However, there's really nothing that would indicate any other problem, no tire wear, no rattling, no jumping from side to side, etc. The car just doesn't feel real tight. It may be that's more reflective of the style and year of the car as its hard not to notice a huge difference between my 99 dodge p.u. and the 66.
Could just be the crappy roads we have here in Fergus County....
I'm running some decent radials with little to no tire wear but I want to get the front end checked out before I do to much serious road time.
thanks for the input
Old Jun 1, 2003 | 06:52 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Like John said, a good aligment man will inspect for any related issues. Also like he said, the rear alignment can be tricky. Unless the local shop can make you feel confident that they are experienced with Corvettes, I think a trip to the "big city" for a shop that is would be worth the trouble and expense to make sure it gets done right.
Old Jun 1, 2003 | 11:32 PM
magicv8's Avatar
magicv8
If you have radials, tell the shop to use 76 Corvette specs to align for a Vette with radial tires. Worked for me for 15 years. :lurk:
Old Jun 2, 2003 | 08:18 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Default Re: Alignment (magicv8)
Your 66 Vette will NOT ever drive like a new rack & pinion. Might be good for your mental health to have it checked by a pro. ;)
Old Jun 2, 2003 | 09:14 AM
magicv8's Avatar
magicv8
Default Re: Alignment (vettes1st)
IMO, my 66 tracks straighter and has better road feel than any rack and pinion car I have driven. I wish my new Pontiac had 66 Corvette steering in it. The 2003 Pontiac has been back to the dealer 5 times to try to keep it from wandering. The dealer has even replaced the tires. It is also my 25th car, so I have sampled a good cross section of the rack and pinions out there.
Old Jun 2, 2003 | 12:18 PM
SWCDuke's Avatar
SWCDuke
Could you be more descriptive?
Do you mean that the steering has noticeable play on center or is the on-center feel poor? Also what kind of tires do you have?
Excess on-center play would call for a thorough inspection and analysis of the entire steering system from the steering wheel to the road wheels. C2s generally have good on-center feel and self centering due to caster, but tires have a big inpact, too. Lack of on-center feel can be improved with more caster, but the tradeoff is greater effort, especially at low speed.
Duke
Old Jun 2, 2003 | 10:41 PM
6tee6's Avatar
6tee6
Default Re: Alignment (SWCDuke)
My choice of words may not be the most accurate. When I say "loose" what I mean is the car seems to wander a little at higher speeds. Nothing in the steering really feels loose or "rattly" like its unsafe or somethings coming apart.
Nevertheless, I did find a mechanic who at least appreciates older cars and will check out the basics for me.
I'm running Goodyear Radials 205/75-15
Old Jun 3, 2003 | 02:47 AM
SWCDuke's Avatar
SWCDuke
You need more caster. Spec for '63 is 1.75 degrees, but I recommend more for those who can deal with a little increased steering effort at low speed as it will increase on center feel at speed and make for better straight line tracking. For power steering I recommend at least 2 and maybe even 2.5 degrees.
Duke
To Alignment
