Surging when accelerating
Old Jun 6, 2003 | 01:51 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Surging when accelerating (bondo478)
you can convert to a electric choke but not the GM style and it sounds like you are going the right direction. keep us posted :chevy
Old Jun 6, 2003 | 09:31 AM
bondo478's Avatar
bondo478
Default Re: Surging when accelerating (clem zahrobsky)
Drove it to work today. It's MUCH better than it was but still not exactly right. I think the #67's may clear it up. I hope so.
Old Jun 6, 2003 | 10:16 AM
clem zahrobsky
Cruise-In I Veteran
did you look to see what power valve was in the carb? :chevy
Old Jun 6, 2003 | 10:54 AM
bondo478's Avatar
bondo478
Yes, it was a 65 so I left it for now. Think I shoud try a different one?
Old Jun 6, 2003 | 11:30 PM
clem zahrobsky
Cruise-In I Veteran
#65 sounds good. :chevy
Old Jun 7, 2003 | 10:45 AM
Matt Gruber's Avatar
Matt Gruber
for a quick test, disconnect the vac. advance.
see if it improves.
Old Jun 17, 2003 | 04:21 PM
bondo478's Avatar
bondo478
I put the #67's in today and it is a world of differnce!! It still does surge just a little bit but at least we are on the right track! Should I try one jet higher again?
Old Jun 17, 2003 | 08:06 PM
DansYellow66's Avatar
DansYellow66
Default Re: Surging when accelerating (Matt Gruber)
:iagree: Try Matt Gruber's test. Too much vacumm advance shows up in my car mostly at steady cruise but also light acceleration. It appears to be a common problem with today's fuels. :steering:
Old Jun 18, 2003 | 11:50 AM
kyosho's Avatar
kyosho
Default Re: Surging when accelerating (DansYellow66)
I had something similar like this happen two nights ago. I had noticed my car getting steadily worse and worse. Mine was more surging during cruising. Then, all of the sudden the car stopped running. I would crank and start, then die.
What caused it? The + wire going to the coil was loose. Actually, it kind of cracked out of the connector. Fix the connector, revs up to 5500 now no problem, and cruises nicely.
Old Jun 27, 2003 | 03:15 PM
Matt Gruber
no quick test?
:nopity
Old Jun 27, 2003 | 03:17 PM
Matt Gruber
no quick test?
:nopity
for a quick test, disconnect the vac. advance.see if it improves.
Old Jun 27, 2003 | 04:07 PM
bondo478's Avatar
bondo478
Sorry, hadn't gotten much of a chance lately to mess with it. Disconnecting the vac advance did help a bit but not very much. I've done larger jets which seemed to help but it's still not gone. Power valve?
