63 Coupe Numbers Help
Old Jun 11, 2003 | 10:04 AM
63fuelie's Avatar
63fuelie
Default 63 Coupe Numbers Help
I am new to this forum but I am in hopes that someone can help me with IDing numbers on the 63 fuelie coupe I just purchased. I have the corvette black book but that does not give the info on everything. For example, the black book does not give the numbers for the code 900, Tuxedo Black cars. Also, I was hoping to get numbers for other things such as the water pump, intake, transmission, tail shaft, rear end etc. Is there any resource out there for this or anyone that would be willing to help?
Thanks,
Al Barlow
Thomaston, Maine
Old Jun 11, 2003 | 12:58 PM
JohnZ's Avatar
JohnZ
Default Re: 63 Coupe Numbers Help (63fuelie)
If you don't have them, you need the '63 Corvette Assembly Manual, Noland Adams' Corvette Restoration & Technical Guide, Vol. II, the NCRS 1963 Corvette Technical Information Manual & Judging Guide, plus the 1963 Corvette Shop Manual; this is the absolute minimum technical library to start with. All except the Noland Adams book are available from the NCRS on-line store at http://www.ncrs.org, and Noland's book is available from all the resto parts houses or direct from Noland (nolandadams@internet49.com). :thumbs:
Old Jun 11, 2003 | 10:29 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
all of these are assuming you have a 360 hp fuelly - all of these will also be date coded to your VIN of the car - also, as indicated buy some of the books and get a parts manual!
Tuxedo Black - Code 900 - Quantity ???
water pump - 3998206
transmission -
tail shaft -
rear end -
fuel pump - 5594657
low note horn - 9000455
high note horn - 9000456
horn relay - 1115824
engine casting - 3782870
cylinder head casting -3782461
intake manifold casting - 3794129
exhaust manifold - l/3797942 r/3797902
fuel injection - 7017375
air meter - 7017248
fuel meter - 7017277
distributor - 1111022
coil - 1115087
37 amp alternator (no a/c) - 1100628
52 amp alternator (a/c) - 1100633
wiper motor - 5044518
starter - 1107242
aluminum radiator - 3155316
overflow tank - 3155416
Old Jun 13, 2003 | 10:00 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Default Re: 63 Coupe Numbers Help (mdz06vetter)
Welcome to the forum, you should get all your questions answered here. Lots of good people with much experience. Enjoy your car. :cheers:
To 63 Coupe Numbers Help
