62 window adjustment
Old Jun 18, 2003 | 12:36 PM
belladonnabella's Avatar
belladonnabella
Default 62 window adjustment
I thought I just posted but I dont seen it so here we go again. I have a 62 that has problems rolling up or down the windows. I can do it as long as I wiggle the window back and forth.
Can somebody tell me how hard it would be to fix as well as a rough cost.
Thanks,
John
Old Jun 18, 2003 | 12:45 PM
kcust62's Avatar
kcust62
Default Re: 62 window adjustment (belladonnabella)
Thanks,
John
John, you have a reply on your original post under "62 window sticks"!
Old Jun 18, 2003 | 02:33 PM
62fuelie's Avatar
62fuelie
Default Re: 62 window adjustment (kcust62)
This could be due to a variety of problems, ranging from a bad regulator to someone having installed one of the current reproduction rear channel liners. There are also some nylon rollers on the window tracks that need replacing. None of this stuff is real expensive unless you need new regulators. If it's both windows, I doubt it's the regulators. You're just going to have to take them apart and see what's binding. There are good instructions in the ST12.
Old Jun 19, 2003 | 01:05 AM
belladonnabella
Default Re: 62 window adjustment (62fuelie)
Thanks to all for the response. I have changed the door hinges on the drivers side and at that time had the panel off and actually looked inside but I didn't attempt to do any adujusting.
I will definetly attempt to fix the windows and may need more detailed help in the future.
Thanks again for the response.
John
To 62 window adjustment
