Engine smokin
Old Jul 13, 2003 | 05:19 PM
LENNY66's Avatar
LENNY66
Default Engine smokin
Went for a cruise in car today, when blue smoke started coming out of passenger tailpipe. I had the engine rebuilt about 200 miles (and 2 years) ago. The smoke has to be oil by the smell. The car was down about a pint in a 20 mile trip. Car also seemed to be ideling higher after. The engine has been using oil since rebuild, but nothin like this. Car is 66 vette with 427. The engine is bored over, and new pistons were put in. Any suggestions on what it could be would help. CAr has been sitting all year because of brake problems, had them fixed last week and put new tires on today when car went down again :mad Anyone want to buy a car? :lol:
Old Jul 13, 2003 | 10:41 PM
ghostrider20's Avatar
ghostrider20
Default Re: Engine smokin (LENNY66)
Sounds like you may have blown an intake gasket, on one of the runners, and it is ingesting crank case air/oil. This would explain the high idle (vac leak) and the oil consumption being bank sensitive.
Mark
Old Jul 13, 2003 | 10:51 PM
achapman's Avatar
achapman
Did you take out the plugs on the passenger side and check them for oil? If not this is the first place I would look. Like the previous post said it could be as simple as a gasket..... :yesnod: or ..... :crazy:
Good Luck.... :cheers:
Old Jul 14, 2003 | 09:20 PM
LENNY66's Avatar
LENNY66
Default Re: Engine smokin (achapman)
Their was a little oil on the middle plugs on passenger side. It was on the threads. What does this tell me?
Old Jul 14, 2003 | 10:10 PM
MOTORCITY's Avatar
MOTORCITY
You can spray carb cleaner around the intake gasket area and the carb base to check for a vac leak and also around the vac lines to find the possible leak. also your engine only has 200 miles on it, it isn't even broken in yet.
Old Jul 22, 2003 | 09:53 PM
LENNY66's Avatar
LENNY66
The rocker stud is broke in half. What could cause this? How tuff a fix? And why would this stud break? Also car seems to have used alot of fuel for short amount that its been on, is their any relation? Thanks in advance.
Old Jul 24, 2003 | 07:10 AM
6T7L71CPE's Avatar
6T7L71CPE
LENNY66,
I had a rocker stud break clean in half on my 67 rectangular port heads. It was cracked within the space under the adjusting nut so it didn't SWARM on me going down the road. Luckily I came across it while adjusting the valves. The studs screw out, simple fix. Someday when I rebuild I'm putting all new ones in.
To Engine smokin
