calling MasterDave ..
Old Aug 14, 2003 | 04:23 PM
mrg's Avatar
mrg
Default calling MasterDave ..
Dave, at the risk of rehashing another round of "will it fit" posts didn't you say you were running the Weiand Stealth aluminum intake manifold under the hood of your '64 .. ? .. I think you said you used a drop base 3" air cleaner on a Holley carb to top off the works, if memeory serves correctly.. .. Or was it an AFB .. ? .. There's also a new similar topic in the forum asking about fitting the Performer intake manifold and AFB carb/air cleaner setup under a stock small block hood. At some point I would like to install either one of these manifolds topped of with my AFB carb/air cleaner too; depending on which setup better fits underneath the stock small block hood .. Did your setup work out ok .. ? ..
mrg
