C-2 Leaf Spring
Old Sep 2, 2003 | 09:03 PM
plaidside's Avatar
plaidside
Default C-2 Leaf Spring
My son has a stock 64 that needs a rear leaf spring. I just checked Zip's online catalog and they list 7 leaf HD and 9 leaf STD. We don't know which one to order.
Common sense would say the the 9 leaf should be HD.
He wants a good ride and the car to sit properly.
Thanks.
Old Sep 2, 2003 | 09:16 PM
396 RAT's Avatar
396 RAT
Default Re: C-2 Leaf Spring (plaidside)
(7) is HD, (9) STD.
This topic is wide open. No right answer.
How does he intend to drive it?
I would go for the 7, others the 9.
Tried a Glass spring on my 65 365 coupe replacing the stock (9 leaf)
and hated it!
Wished I would have gone with the stock 7 on that car.
Again, what I like, and your son likes may be worlds apart.
Putting around? Spirited driving? What is he going to use for shocks and tires?
NCRS orig type goal? Fun canyon car? Get my drift?
"My son has a stock 64 that needs a rear leaf spring. We don't know which one to order. "
Whats on it now? Is he happy with it, but its sagging?
Or does it feel soft? Why the need for the new spring?
:seeya
[Modified by 396 RAT, 8:38 PM 9/2/2003]
Old Sep 2, 2003 | 09:37 PM
SWCDuke's Avatar
SWCDuke
Why do you think it needs a new rear spring?
Duke
Old Sep 3, 2003 | 03:17 AM
Mikey1's Avatar
Mikey1
Default Re: C-2 Leaf Spring (SWCDuke)
Well...if the orignial spring its flat.....and the body comes down too deep...then it´s about time. Seen too many aading washers to adjust ride height :smash: ...bubba technology.
Agree that this is a question of what you want.
Keep an orginal car original. Adjust a driver to your driving needs. :cheers:
Old Sep 3, 2003 | 05:07 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: C-2 Leaf Spring (Mikey1)
A word of caution.....the current "repro" springs look nothing like the originals, and I have heard/read that many have had ride height issues with them. The 7 leaf is the HD spring.....makes your car ride like a buckboard, and will likely make the car sit "lower" than the standard 9 leafer.
You can rebuild your original spring, using new liners. BTW....on the car...the rear spring usually is flat "under weight". :) Chuck
Old Sep 3, 2003 | 09:30 AM
66427-450's Avatar
66427-450
Default Re: C-2 Leaf Spring (66427-450)
Well, what's on the car now? 7 or 9?.... Unless someone’s messed with it, it's got one of the factory spring setups, and the front and rear springs are balanced to provide proper handling (the 7-leaf rear requires heavy front springs as well).
if you actually need a new spring (do have a broken leaf of something) i'd replace it with the type that's on there now. If you want it to handle better, get a good set of modern performance shocks and tires, and make sure all the suspension bushings are in good repair.
:seeya
Old Sep 3, 2003 | 10:17 AM
Daren Schneider's Avatar
Daren Schneider
My 2 cents. Rebuild the stock spring. I had same problem in my 67 with mine, bought new spring from LIC and was a piece of junk made in mexico. I tried to return but they refused. I installed the new one. I kept my stock one and will put back one day.
Old Sep 3, 2003 | 10:21 AM
SWCDuke's Avatar
SWCDuke
Most "spring sag" problems are just compessed and hardened spring link cushions - ten bucks in parts that take an hour or less to change.
At curb weight the spring should be nearly flat.
Unless the spring is broken of has severe corrosion, it probably doesn't need to be replaced.
Duke
Old Sep 4, 2003 | 12:48 AM
SWCDuke's Avatar
SWCDuke
Forgot to add that new spring link cushions will dramatically reduce rear ride harness. It will feel like a new car!
Duke
Old Sep 4, 2003 | 08:16 AM
66427-450's Avatar
66427-450
yes, i tried poly "donuts" and went back to rubber...... the only place i'm using poly is the rear struts bushings and sway bar links
Old Sep 4, 2003 | 07:58 PM
plaidside's Avatar
plaidside
The reason we are replacing the spring is there are two broken leafs on the left side, which is sagging.
We put all new bushings in the rear already.
The car was laying for almost 20 years and when we redid all the bushings we didn't notice the broken leafs.
My son just loves to drive the car. He doesn't race it or road course it.
He just wants a nice driver.
Thanks for all your replys.
Old Sep 9, 2003 | 11:23 PM
silverslashstreak's Avatar
silverslashstreak
Take a look good look at the glass spring when you set it up correctly it will out ride and out handle the old metal spring. Did you ever wounder why they have put them on all corvettes since 198.1
Old Sep 10, 2003 | 08:29 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Default Re: C-2 Leaf Spring (silverslashstreak)
I am with Silverslashstreak...........3 years ago (winter project) installed 330LB TRW design , composite rear spring..........rides nice, no bounce & reduced wieght by approx 40 LBs.....worked for me, :steering: The Dog. :seeya
Old Sep 10, 2003 | 12:52 PM
66427-450's Avatar
66427-450
:) But a midyear is not a '81-up. Unless you want to create a "Mongrel" lol (i got that from another recent post here)
no offense :seeya
Old Sep 10, 2003 | 01:08 PM
brucep's Avatar
brucep
I am in the process of bringing back a 66 L79 to sweet driver. when I got it it had tired HD springs front and rear. I didn't know this or like the handling. I replaced shocks with delco gas. Still didn't like the ride or the ride height. Finally bit the bullet and put stand spring all around. The car rides much better, handles better and has the proper ride height too. I guess the springs and shocks are balance now. I'd never use those HD springs for a driver street car. I bought the springs and shocks at LI Corvette.
Old Sep 10, 2003 | 03:06 PM
66427-450's Avatar
66427-450
Default Re: C-2 Leaf Spring (brucep)
.......... bringing back a 66 L79 to sweet driver. when I got it it had tired HD springs front and rear
Tired F-41 springs? What do you mean...what were the symptoms?
Old Sep 10, 2003 | 03:35 PM
brucep's Avatar
brucep
low ride height, stiffness level exceeding the stock spec shocks ability to dampen them, hard hard ride.
Old Sep 10, 2003 | 05:03 PM
solidlift's Avatar
solidlift
The 7leaf H.D. is what came stock on the Z06 package for '63. It will ride
a bit firmer.
To C-2 Leaf Spring
