Engine ID Help
Old Oct 13, 2003 | 05:44 PM
newbe60's Avatar
newbe60
Default Engine ID Help
Was doing some work on the engine and found the this ID number on the passenger side almost at the front TIII3R
the engine block is 37828709 which seems to indicate a 327 build between 1962-1965..not sure what the other number is for?? or indicates?
another stamp seems to be F262 which i thought showed it was a 1962 engine build around June?
Old Oct 13, 2003 | 05:55 PM
clcintx's Avatar
clcintx
Default Re: Engine ID Help (newbe60)
Doesn't T mean from the Tonawanda New York plant - the 1113 is the last 4 digits of the VIN and the R is the type of car it came out of (i know what S stands for, but not sure about R)
[Modified by clcintx, 4:55 PM 10/13/2003]
Old Oct 13, 2003 | 06:46 PM
66427-450's Avatar
66427-450
Default Re: Engine ID Help (clcintx)
check this out.......
http://www.mortec.com/locatpg2.htm
http://www.mortec/locations.htm
Old Oct 13, 2003 | 08:33 PM
Denney's Avatar
Denney
TIII3R...another stamp seems to be F262 which i thought showed it was a 1962 engine build around June?
T: Tonowanda engine plant
III3: November 13
R: 1962-64 327ci 250hp Manual Transmission engine used in passenger cars.
F262: Cast date of June 26, 1962
:cheers:
Old Oct 13, 2003 | 10:34 PM
newbe60's Avatar
newbe60
Default Re: Engine ID Help (Denney)
the numbers are not the nuber 1 but capital I ..unless chevy used the letter I for 1's
Old Oct 14, 2003 | 10:03 AM
Denney's Avatar
Denney
With regard to the use of I for the number 1, that was fairly common in stamping of engine pads, they are essentially interchangeable when it comes to numbering. That number (the November date) was the engine assembly date.
Old Oct 14, 2003 | 12:05 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
"R" is a 62/64 327 ci 250 hp M/T passenger car
To Engine ID Help
