63 engine configuration
Old Oct 19, 2003 | 07:54 PM
fcabarle's Avatar
fcabarle
Default 63 engine configuration
Did GM build a 63 with a 340hp engine and auto transmission? :confused:
Old Oct 19, 2003 | 08:11 PM
SWCDuke's Avatar
SWCDuke
Default Re: 63 engine configuration (fcabarle)
No, manual only - three speed standard, optional four-speed, close ratio only, choice of six axle ratios from 3.08 to 4.56. Same for FI engine.
Duke
Old Oct 20, 2003 | 09:29 AM
fcabarle's Avatar
fcabarle
Default Re: 63 engine configuration (SWCDuke)
OK, so how do I find an original type close ratio transmission; what numbers do I look for on the transmission, do I need an M-20 Muncie or a T-10? Incidently, the car came with all the parts to "convert" back with exception of the bell housing, throwout bearing arm and transmission.
Old Oct 20, 2003 | 11:05 AM
JohnZ's Avatar
JohnZ
Depends on the car's VIN - the running change from the T-10 to the Muncie occurred about #14800, and 1963 cars used a bellhousing with a smaller hole for the front bearing retainer than 1964 and later cars, which had a larger front bearing retainer diameter and matching bellhousing hole. 1963 Muncie shift linkage rods are also different than 1964 and later linkage. :thumbs:
To 63 engine configuration
