How do you remove C2 ignition switch
Old Oct 27, 2003 | 09:37 AM
Daren Schneider's Avatar
Daren Schneider
Default How do you remove C2 ignition switch
Well I pulled the dreaded 67 dash cluster last night (1 hour fiquring out what steering colums bolts to remove, 1hour for taking the dash cluster out and labeling wires.) However I cannot get the ign switch out. I was able to take out the ign switch tumbler. How do you remove Ign Switch. I need to take cluster out for rebuild.
Old Oct 27, 2003 | 10:19 AM
JSB69's Avatar
JSB69
Default Re: How do you remove C2 ignition switch (Daren Schneider)
Unscrew the slotted chrome bezel nut. Lock cylinder must be out.
Old Oct 27, 2003 | 11:16 AM
Daren Schneider
I take it the nut is on the outside of the cluster. Do I wrap it with a towel, then grip it with pliers. I do not have the wrench for it.
To How do you remove C2 ignition switch
