To Replace a throw out bearing?
327/ 300 hp engine and a four speed(?). There is a dust pan (inspection
pan) at the bottom of the Fly wheel. Do I have to pull the engine to change the throw out bearing???
I had a great drive today . About 60 miles. She still has a skip. I think plugs will help. sHE HAS R43 PLUGS and I am not keeping them blown clean.
AUpAUL :steering:
There have been a few posts in the past on how to replace a throw-out bearing. Do a search in the archives under "clutch slips on my 62" dated 10/23/2002, and you should come up with some very usefull tips.
Below is what I think is the direct link:
http://forums.corvetteforum.com/zerothread?id=417958
Basiclly you do not remove the engine, but do remove the dust cover, driveshaft, shifter, and then trans. The rear of the engine needs to be supported with a saddle/girdle (made of wood that goes under the oil pan and up both sides of the pan to support at the oil pan rails to the block - see above search for a picture). Do not attempt to support the rear of the engine on the bottom of the oil pan, unless you want a dented pan. The saddle is then supported by a jack. Once the trans is pulled out, the throw-out bearing is a snap to replace. Just get the correct one (several different lengths were used over the years), and install it correctly on the fork. If you think the clutch plate needs to be looked at, now is the time to do it!
Note that I have pulled/replaced the trans by myself (as of last year - twice, don't ask - all 58 years old, 138 pounds of me), but I would think it a lot easier with 2 people! I am just stubborn and pig headed enough to do it by myself!
Good luck,
Plasticman
[Modified by Plasticman, 10:04 PM 11/2/2003]
When you install the bearing on the end of the clutch fork, both the flat spring AND the "curled" ends of the fork go IN THE GROOVE of the bearing; it's possible to install it wrong (curled ends of the fork capturing the flange at the rear of the bearing), and you won't be able to adjust the clutch. :thumbs:
That's a fairly bold statement, not eveyone uses a stock clutch. There are different bearings for different style clutches. I can think of at least three different syles plus some clutch makers use there own bearing.
Edelbrock 1406 carb..
I have gotten some great info here about the throw out bearing. One more question. If you ONLY wanted to swap the Throw out bearing. What would do? Do you still need to unbolt the shifter? Can just slid the trans back and let it rest on the bell houseing? Then replace the TOB with out putting the trans. on the floor? She only has 800 miles from a rebuild and the clutch feels good..
AUpAUL :flag
Mine has a Muncie, and yes I could slide the trans back and rest the input shaft on the lip of the bellhousing to replace just the throw-out bearing. But, I would still need to remove the shifter before the trans will go backwards.
Also, with the trans just sitting there, I sure would not want it to slip off the bellhousing lip (could hurt one of the more important pieces - on you).
Plasticman
