64 build sheet
Old Nov 5, 2003 | 10:49 PM
acowboy's Avatar
acowboy
Default 64 build sheet
hello from a new member....been watching here a while, and is a good forum....question is, where to look for build sheet on 64, or did build sheets not happen till 67?? TIA
Old Nov 6, 2003 | 12:05 AM
wombvette's Avatar
wombvette
Default Re: 64 build sheet (acowboy)
They happened, but dont count on finding one in a 64.
Old Nov 6, 2003 | 09:37 AM
vetzs's Avatar
vetzs
There was an article in the Nov 03 issue of Corvette Enthusiast tited "Finding that Hidden Documentation" by Noland Adams. He mentions a 65 owner that found a broadcast sheet (build sheet) after removing the fresh air grill in the passenger side kick panel. Behind this grill is a valve that allows fresh air into the vehicle. It was after removing this valve that a crumbled up build sheet was found directly behind the door hindge. Per the article it may take some digging in the well area to find anything. Worth a try, I have a 64 and am looking forward to investigating this area. I do have one suggestion, if you see something try to use care, I'm sure any documents that old will be a bit delicate. Later....vetzs
Old Nov 6, 2003 | 04:09 PM
acowboy's Avatar
acowboy
thanks for the response......yea, i know to be careful....found them for my 70 e.c. and my 70 goat....both over the gas tank
Old Nov 7, 2003 | 10:42 AM
ARed64's Avatar
ARed64
I have not found one yet in mine but I did find one of the original keys tucked way up in under the seat when I had it out one day. You never know what you might come across when poking around in these cars.
Old Nov 7, 2003 | 02:41 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
My son and I are doing a total frameoff and we disassembled absolutly everything and never found any sign of a build sheet. While we were disappointed we were not surprised. Never pass up any hidden crevices.
Old Nov 8, 2003 | 06:04 PM
blitz10's Avatar
blitz10
Strange things can happen. I was driving a 52 international 1 ton that my father had given me and the build sheet came out from under the dash. I had the A/C on, the air scoop in front of the windshield, and the wind must have caught it right to dislodge it. 50 years and it never came loose. I thought it was neat and saved it, it was in pretty good condition and easily readable.
Old Nov 9, 2003 | 11:50 PM
mikes64's Avatar
mikes64
I found a build sheet under the carpet in my 64. It is in pretty
good shape and I have photocopied it and placed the original
in the safe. Maybe you will find yours, but like others say, good
luck.
Mike
Old Nov 10, 2003 | 01:51 PM
Tom Piper's Avatar
Tom Piper
Default Re: 64 build sheet (mikes64)
luck.
Mike
I replaced the carpeting in my '64 coupe, but I didn't take the jute padding under the carpeting out.
Did you find this under the padding or just under the carpet?
Tom Piper
Old Nov 10, 2003 | 10:54 PM
Milehigh66's Avatar
Milehigh66
Default Re: 64 build sheet (ARed64)
The original owner taped one of the original keys under the front left bumper, found it when I took it apart for painting. Man, was that some crusty old tape, may never get the tape residue off of the key. :crazy:
Still hoping to find some documentation hidden somewhere.
Kurt
Old Nov 12, 2003 | 07:11 PM
mikes64's Avatar
mikes64
Default Re: 64 build sheet (Tom Piper)
Tom:
Found it under the carpet.
Mike
To 64 build sheet
