Need tips on pulling small block
Old Nov 21, 2003 | 11:38 PM
kikomax's Avatar
kikomax
Default Need tips on pulling small block
Gonna pull the engine next weekend in my 65 and have it rebuilt. It's a 4sp with air. any tips/advice or sites I should go to read up and make this as smooth and painless as possible.
Thanks in advance. I'm just starting this resto so I may be asking alot of dumb questions soon.
Oh yeah, since we're on the subject, is there anywhere I can get a choke assembly for the Carter AFB 3721SB cheaper than $185 from Edelbrock?
Old Nov 22, 2003 | 08:28 AM
mac383's Avatar
mac383
Default Re: Need tips on pulling small block (kikomax)
If you are going to do a full body off, you might want to consider pulling the body prior to pulling the motor. Just MHO. :D
Old Nov 22, 2003 | 08:34 AM
Kid_Again's Avatar
Kid_Again
...very straightforward...i pull the tranny, some guys don't...i assume you're pulling the heads, etc first
[Modified by Kid_Again, 8:35 AM 11/22/2003]
Old Nov 22, 2003 | 12:09 PM
six-T-six's Avatar
six-T-six
St. Jude Donor '03 & '05
Default Re: Need tips on pulling small block (Kid_Again)
I pull the tranny first too. If you don't, get a load leveler, it'll make it much easier to try to tilt the whole thing out.
Old Nov 22, 2003 | 04:32 PM
Daffy2's Avatar
Daffy2
While you have the hood off and the rad. out, slick up the engine compartment, look over the headlight motors and adjustment pieces and make any needed repairs. If your tranny tunnel is missing the insulation there's no better time to add it. For sure go for a fresh throwout bearing and examine the clutch fork. Add petcocks to the block before you reinstall for easier coolant flushes. Do repairs to the battery tray if needed. Check over the tranny mount. This is a perfect time to replace u-joints if they aren't in great shape. Fresh needle bearing in the back of the crank instead of a bushing. Shifter rebuild?
It's a great time to do some small things that are more difficult when the motors in and the hoods on.
Daffy
Old Nov 22, 2003 | 08:53 PM
Hitch's Avatar
Hitch
Default Re: Need tips on pulling small block (Daffy2)
Just did this.. I pulled the everything off down to the short block and the tranny. It was very easy. I didn't remove the yoke b/c I didn't have plug at the time. I just wire tied it in so it would fall out and let all of the xmission fluid out.. I didn't use a leveler either just my floor jack under the tail shaft and as I lifted the motor out and foward it keep me at the right angle and didn't let the tail shaft hit anything. Needless to say this was the first time I removed an engine and not only did I not have any problems I did it by myself. So just as everything else just get out there and do it man. If you are careful you will have no problems. I used 5/8ths chain and #8 bolts to secure it to the hoist.. Dave..
Old Nov 22, 2003 | 09:06 PM
Guest
Guest
Posts: n/a
Here is the way I did it and man, what a piece of cake!! lol:
http://temp.corvetteforum.net/classi...gineinst.2.jpg
To Need tips on pulling small block
