Frame Serial Numbers
Old Dec 24, 2003 | 12:37 AM
six-T-six's Avatar
six-T-six
St. Jude Donor '03 & '05
Default Frame Serial Numbers
Anyone know exactly where the second location of the serial number is on the drivers side frame rail? I was able to find remnants of the first number on the kickup right close to the where the body mount is. Unfortunately I can only make out 6SI of the first number. The stamping must have been very light. I wonder if there is any way to make the stamping reveal itself where I can't see the rest of the numbers.
Old Dec 24, 2003 | 11:15 AM
JohnZ's Avatar
JohnZ
Default Re: Frame Serial Numbers (six-T-six)
The second stamping is about a foot forward of where the kickup starts up. :thumbs:
Old Dec 25, 2003 | 10:26 PM
six-T-six's Avatar
six-T-six
Default Re: Frame Serial Numbers (JohnZ)
Thanks John, going to a close look and see if I can spot them.
Old Dec 26, 2003 | 08:29 AM
78Vette-SA's Avatar
78Vette-SA
Six, in the pic below, the forward VIN # is about halfway between the jackstand and the edge of the pic. You can see a darker spot on teh top frame rail which is where I cleaned the numbers off.
Old Dec 26, 2003 | 12:11 PM
six-T-six's Avatar
six-T-six
Default Re: Frame Serial Numbers (78Vette-SA)
Joe,
Could you see your numbers clearly? I can only see remnants on the kickup and none at all on the side frame. Too much corrosion. :(
Old Dec 26, 2003 | 01:02 PM
JohnZ's Avatar
JohnZ
Clean the surface off with a Scotchbrite pad and a toothbrush, wipe white shoe polish on it, then wipe the surface with a rag; some of the white shoe polish will remain in the stamping and make it easier to see. :thumbs:
Old Dec 27, 2003 | 09:31 AM
78Vette-SA's Avatar
78Vette-SA
Joe, Could you see your numbers clearly? I can only see remnants on the kickup and none at all on the side frame. Too much corrosion. :(
Yes, sort of. Although fainter then the numbers on the rear kickup, they are legible. I just took a little simple green and a wire brush and was able to see them after wiping with a rag. I like the shoe polish idea above though. Good tip!
This isn't the best pic but I lightened a little right on the numbers (S119761).
To Frame Serial Numbers
