Engine code letters decal location?
Old Jan 4, 2004 | 08:12 AM
sams'66's Avatar
sams'66
Default Engine code letters decal location?
Where are they supposed to be?.....can't find the location in the AIM.
Thanks! :thumbs:
Old Jan 4, 2004 | 09:40 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Engine code letters decal location? (sams'66)
I'll go out on a limb here, and say I "THINK" they belong on the vertical surface...on the back of the passenger's side valve cover. Chuck
Old Jan 4, 2004 | 09:53 AM
JL66REDCPE's Avatar
JL66REDCPE
C2 of Year Finalist (stock) 2019
Default Re: Engine code letters decal location? (Chuck Gongloff)
C'mon Chuck -- you are being modest. That is exactly where it goes. From the 66 JM -- " an engine code identification sticker is located on the rear end of the right side valve cover "
[Modified by JL66REDCPE, 9:53 AM 1/4/2004]
Old Jan 4, 2004 | 11:47 AM
sams'66's Avatar
sams'66
Default Re: Engine code letters decal location? (JL66REDCPE)
Thanks guys!
Anyone have a photo of thr letter placement?
Old Jan 4, 2004 | 12:30 PM
66427-450's Avatar
66427-450
check your mail..... i've seen them stuck on centered on the rear surface of the valve cover, as well as well as at some odd angle, it wasn't really done with care
Old Jan 4, 2004 | 12:31 PM
Chuck Gongloff
Nah...not being modest, but I don't have a 66 JG. Most I've seen go there. Here's another thought......individual letters, i.e. "L" and "M" each individually glued there, or a single label "LM"? Thoughts? Chuck
Old Jan 4, 2004 | 01:59 PM
JohnZ's Avatar
JohnZ
66's had a single label with two letters on it; doesn't show up in the A.I.M., as it was part of the engine as received from the engine plant. :thumbs:
[Modified by JohnZ, 2:00 PM 1/4/2004]
Old Jan 4, 2004 | 02:15 PM
sams'66's Avatar
sams'66
Default Re: Engine code letters decal location? (JohnZ)
one sticker....with both letters?.....crap! the parts houses sell them as individual letters.....they are yellow with black letters. :U
Old Jan 4, 2004 | 03:11 PM
JohnZ's Avatar
JohnZ
LICS has the correct ones for midyears - I believe the "separate-letter" types started with some C3's, although that's still up for grabs according to some C3 folks. :thumbs:
To Engine code letters decal location?
