Engine numbers
Old Jan 13, 2004 | 06:19 PM
big-apple's Avatar
big-apple
Default Engine numbers
Have had my '64 vert little over year---just want to try and pin down the engine in it-----motor# is V07100RE---casting number is 3070010--it has the intake for SHP 66 or 67-----Valve covers have the flaw---even though I know that does not mean much---thanks in advance Apple
Old Jan 13, 2004 | 06:28 PM
Bullshift!'s Avatar
Bullshift!
Default Re: Engine numbers (big-apple)
The casting number of the engine block in 64 was 3782870, and they were assembled in my hometown, Flint, and should have an engine number prefex "F".
I'm not sure what you have there that starts with "V", anybody else know?
Alann
Old Jan 13, 2004 | 06:33 PM
Bullshift!'s Avatar
Bullshift!
I did a little more looking and found that in 67 Chevrolet opened a new engine assembly plant that used the "V", but it was followed by only four (4) numbers, not five like yours.
I'll keep on it...
Alann
Old Jan 13, 2004 | 06:34 PM
big-apple's Avatar
big-apple
Default Re: Engine numbers (Bullshift!)
thanks bullshift-------I am thinking this is a 66 engine------I may have the numbers wrong I got them some time ago---just getting around to inquiring---
Old Jan 13, 2004 | 06:38 PM
big-apple's Avatar
big-apple
that might be possible I might have an extra 0 in there---going to look again----light in poor in the garage tkas
Old Jan 13, 2004 | 06:45 PM
Bullshift!'s Avatar
Bullshift!
Yeah, light that baby up, cause the casting number should be alot different if it is from a midyear Vette. And give that date code another check as well cuase I'm not finding an RE on anything either.
Just curious, is you VIN number on the block?
Alann
Old Jan 13, 2004 | 06:47 PM
big-apple's Avatar
big-apple
looks more like V7100RE-----------casting number is ok--3070010----just trying to figure this 40 year old out 15th is birthday built 1/15/1964----I think
Old Jan 13, 2004 | 06:51 PM
Bullshift!'s Avatar
Bullshift!
Actually, come to think of it, in 64, RE meant it was a 365 HP engine. But it was prefixed with an "F" back then.
Alann
Old Jan 13, 2004 | 07:00 PM
Bullshift!'s Avatar
Bullshift!
I'm stumped... Hang in there though, it won't be long until one of the smart guyz get home from work and they will tell you X-actly what you have under that hood.
:confused:
Old Jan 13, 2004 | 07:12 PM
78Vette-SA's Avatar
78Vette-SA
It's not "3970010" by chance?
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
JJMURFS's Avatar
JJMURFS
Let's think about this for a minute, the 3970010 block was made from 1969 thru 1975 so it's not a mid year engine to start with. Then in 1970 Chevrolet went to a 3 letter suffix starting with a "C" for passenger cars and a "T" for trucks. So if we look at those numbers again "V07100RE" maybe that last "0" is really a "C", so then the number would be V0710CRE, and that would be a 1970 350/300 hp with an automatic. Thats just a guess, but check it out.
[Modified by JJMURFS, 8:52 AM 1/14/2004]
Old Jan 13, 2004 | 09:11 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Here is a site that has lots of GM casting numbers. You may want to pull a valve cover and check the head casting number. The block number and head number together may help tell you what you want to know.
http://www.mortec.com/
Old Jan 13, 2004 | 10:41 PM
Allcoupedup's Avatar
Allcoupedup
Does the blovk have the crankcase opening by the distributor?
Brian
Old Jan 14, 2004 | 01:22 PM
JohnZ's Avatar
JohnZ
Default Re: Engine numbers (Allcoupedup)
Flint V-8-built engines had an "F" prefix from 1955 to 1966; it was changed to "V" at the beginning of the 1967 model year to avoid confusion between Flint V-8 and the Flint Motor Plant, which built six-cylinder engines and also used the "F" prefix. The 3970010 block was used for twelve years ('69-'80) for 350's in all car lines and trucks, in both 2-bolt and 4-bolt configurations. No 3970010 block ever carried an "RE" suffix, but there was a "CRE" suffix used in 1970 for 350/300's, which would be preceded by a "V"and four digits for the month and day. :thumbs:
Old Jan 14, 2004 | 07:04 PM
Denney's Avatar
Denney
Default Re: Engine numbers (JJMURFS)
:thumbs: This would also be my opinion. By the way, that engine was used in Chevelles, Novas, Camaros, Monte Carlos, and El Caminos but not vettes...
To Engine numbers
