Painting problem
I'm using Duplicolor Semi-Gloss Engine Enamel on top of Kryon Zinc Primer. The parts are first scrubbed in an aqueous degreaser, then reinsed and air-dried via compressor. Bead blasted to clean off old paint and reluctant grime. Then washed, rinsed, and compressor dried again. The I primed and painted the parts.
24 hours after application, the paint is dry, but can be scrapped off by fingernail. Difficult to say whether the primer-metal ineteface, or the primer-topcoat interface is failing.
Is there some step in surface prep that I'm missing?
I'm retrying the parts right now with a lacquer thinner rinse and air-dry (without the compressor) just prior to painting, and no primer.
Thanks,
-Brian
