All the ones you have listed work fine. I have used all of them in the past. I like corvette images because it is so thick that is makes it easy to work with. In the old days we made our own, we used resin with fiberglass mat cut up in it and some bondo it give it body. So you see its not a big deal to bond fiberglass panels as long as they are polyester based.Pick one of the products you have listed and you will be fine. Just make sure you grind both panels so you have good tooth and glue that car together.
