Horn Question?
Old Mar 21, 2004 | 10:18 PM
67's's Avatar
67's
Default Re: Horn Question? (dbbb)
I will try it thanks.
Tom
Old Mar 22, 2004 | 01:35 AM
67's's Avatar
67's
Default Horn Question?
Is there an easy way to test horns?
Thanks,
Tom
Old Mar 22, 2004 | 02:19 AM
dbbb's Avatar
dbbb
Default Re: Horn Question? (Tom McCabe)
I use a 12V battery charger set to the 6 amp setting with an in line 5 amp fuse. You can also use this set up to test the relay, headlight motors, etc.
Hope this helps.
To Horn Question?
