Distributor orientation??
Old Mar 24, 2004 | 09:24 AM
kcust62's Avatar
kcust62
Default Distributor orientation??
I think this was covered in a previous post, but, I tried something yesterday which did not work. The distributor orientation on my '62 has always been approximately 1 tooth clockwise further than it should be. Consequently, the vacuum can prohibits the coil from being mounted in its normal location. My thought was that, if I scribed lines on everything, pulled the distributor, used a long bladed screwdriver to turn the oil pump drive counter clockwise to the equivalent of 1 tooth, reinstall the distributor with all scribe marks aligning, and the orientation of the distributor cap now being in line with the carb and the vacuum can now away from the coil hardware, the problem would be solved. Wrong!!! When the engine was started, it acted as though the exhaust valves were still closed when plug firing occured, causing exhaust to be blown out the crankcase ventilation tube. I put it back to its original location and all was well. Experts, why the heck, didn't this work? What am I missing here?
Thanks!
Karl :banghead:
Old Mar 24, 2004 | 10:10 AM
JSB69's Avatar
JSB69
Default Re: Distributor orientation?? (kcust62)
The drive gear on the bottom of the distributor shaft may be installed wrong. The mark on the gear should align with the tip of the rotor.
Old Mar 24, 2004 | 10:22 AM
JohnZ's Avatar
JohnZ
The objective here is to have the vacuum can nipple pointing at the rear inboard valve cover bolt with the engine at #1 TDC and the rotor tip aligned with the #1 plug wire tower, which is the one immediately clockwise from the adjustment window as viewed from the top. Set the engine at #1 TDC (both valves closed on #1 cylinder), make sure the wires are properly indexed in the cap with #1 wire in the #1 tower, and install the distributor so the rotor tip is pointing at the point on the housing that corresponds with the base of the #1 tower on the cap. While the distributor is out, make sure the drive gear is installed correctly - the "dimple" needs to point in the same direction as the rotor tip, or the upper housing will be 14 degrees out of whack vs. its design position. When you're done, it should look like this, and you'll have adequate range of movement to set the timing correctly without the vacuum advance can hitting either the plug wire support bracket or an intake manifold runner:
:cheers:
Old Mar 24, 2004 | 11:01 AM
kcust62's Avatar
kcust62
Default Re: Distributor orientation?? (JohnZ)
John,
The orientation looked the same as your photo after reinstall and I checked the "dimple" before installing and it appeared to be pointing in the same direction as the rotor. I didn't, however, verify the plug wire locations in the cap. Just assumed they were correct. It runs good when everything looks out of whack, but, like poopie when it looks correct. Anyway, thanks for the tip and I'll have to double check everything I did.
Karl
Old Mar 24, 2004 | 11:32 AM
JohnZ's Avatar
JohnZ
Check the wire indexing in the cap - a previous owner may have re-indexed them incorrectly to compensate for an incorrectly-installed distributor instead of pulling it and doing it right; I see this all the time. :thumbs:
Old Mar 24, 2004 | 02:37 PM
EPL's Avatar
EPL
Active Streak: 90 Days
The prior owner of my 327/365 did something similar. The distributor appeared to be randomly dropped in with #1 at TDC. Then placed the #1 wire where the rotor would line up and finished the firing order from there. I checked a few other cars to see where the VA can belonged, took the distributor out, put #1 at TDC and rewired from there.
Old Mar 24, 2004 | 09:41 PM
toddalin's Avatar
toddalin
When I wanted to "re-clock" my distributor (for the same problem), I pulled the pin and rotated the base 180 degrees and replaced the pin. This put the vac advance in just the right spot.
Old Mar 24, 2004 | 11:01 PM
Denney's Avatar
Denney
Default Re: Distributor orientation?? (toddalin)
That's what JohnZ was referencing regarding the approx. 14 degree shift in the event the dimple does not line up with the rotor tip (i.e. 180 degrees out). I have used this trick myself in the past to buy a half tooth shift, when I found it necessary.
Old Mar 25, 2004 | 08:44 AM
kcust62's Avatar
kcust62
When you say "rotated the base", I assume you're talking about the lower drive gear. I can't imagine being able to turn the actual "base" plate 180 degrees and still have it function.
To Distributor orientation??
