window channel
Old Mar 25, 2004 | 12:22 PM
NCC-1701's Avatar
NCC-1701
Default window channel
I am looking for the window channel for a passenger door on a 66 convertable. Not the window run or the felts but the actual channel itself. Attached to this channel at the top is a stainless steel sleeve that had attached to it the rubber weatherstrip for the vent window. At the bottom is an adjuster screw and nut that is attached to the window channel. I've called varios venders and they say that this is not reproduced. I can't believe this. Can someone help me with a vendor that might sell this new or used. Thanks Angel
