Ahh, thanks YW2BM. I guess that's to make sure PS cars couldn't change steering ratios, whereas manual steering could use either?
Got this from a fellow Forum member. Thanks Bill :-)
The power steering equipped cars had this plug installed in the rear hole of the steering arm from the factory. This was to prevent someone during service from installing the tie rod end in the rear hole which overextends the steering ram and damages the power steering.
It was installed when the front suspension and steering linkage was assembled onto the upside down frame on the assembly line and is thus put in from the bottom of the arm and peened over.
what corvette vendor site is that schematic picture from? its a helluva lot better than the pics in my assembly manual which appear to have been xeroxed 500 times - thanks
Your turning radius drastically increases if you use the outer hole. I shortened my arm by cutting the arm off behind the inner hole.
This is a shot of the cut arm along with a welded spacer to lower the outer tie rod to improve the bump steer curve.
Double click to enlarge
Duke's correct, I think you meant steering ratio not turning radius. Neat modification.
I may be better off with the slower steering, in my early days of driving too fast with not the best driving skills, I'd have to say the slower steering actually saved me a couple times from over correcting in some hairy situations. :lol:
