St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
Re: Temp Sender Again (Tom McCabe)
On my small block I have done it cold. Got me a Towell and unscrewed the sender...a little coolant will leak for a second ..then shove the towell in till your ready to install the new one. I leave the coolant cap on to prevent air from causing fluid flow.
Don't know if this will work on a BB. My sender is in the intake.
:withstupid: It's the same on the BB (it's mounted in the intake manifold as well) :yesnod:
