how wide a wheel
Old Apr 15, 2004 | 01:50 AM
panchop's Avatar
panchop
Default how wide a wheel
how wide a wheel can you get away with with on a stock car, and does anyone make a KO wheel lookalike that is wider then the originials?
thanks
greg
Old Apr 15, 2004 | 10:00 AM
Jim Stewart's Avatar
Jim Stewart
Default Re: how wide a wheel (panchop)
When I was shopping for wheels and tires for my 63 I test fitted several different sizes to determine what would fit on my car. I tried to put on a 15x8 with 4.5 inches of backspacing and the wheel lip hit the end of the stock leaf spring, that was the only point of interference I had. A 15x8 with 4" of backspacing would fit but probably would stick out of the wheel wells. I have since switched to a composite spring and that actually would allow for 4.5" of backspacing on an 8" wide wheel. I am currently using 17x7 with 4 inches of backspacing and 215/50/17 tires.
Old Apr 15, 2004 | 10:46 AM
mjmsc5's Avatar
mjmsc5
CI 2-3-4-5-6-7-8-9 Veteran
CI-4 Car Show Winner
CI-7 Car Show Winner
I have a set of 8" KO look alikes with Michilin X-ones if your intereseted
Old Apr 15, 2004 | 09:18 PM
panchop's Avatar
panchop
Default Re: how wide a wheel (mjmsc5)
I'm interested. my e-mail is panchop440@hotmail.com
To how wide a wheel
