Steering fluid question
Old Apr 25, 2004 | 08:58 PM
vettejoel's Avatar
vettejoel
St. Jude Donor '07-'08-'09-'17
Default Steering fluid question
What kind of fluid do you put in the steering box on a 65 coupe (non-power steering car) and how do you know how much to put in. I took out the bolt that says "checl lube" and didn't see any fluid in there. I also noticed a little fluid leaking out from the bolt on the right. Someone told me to take out the bolt, put a little silicone on it and let it stand for about 20 minutes before I re-install it. Does this sound correct? Thanks in advance :cheers:
Old Apr 25, 2004 | 10:59 PM
Plasticman's Avatar
Plasticman
Default Re: Steering fluid question (vettejoel)
Most C1 and C2 Vette owners have changed to a good grade of Moly fortified chassis grease. The seals on the old gear box have always had a tendancy to leak, so the grease is a better way of going. Corvette Central even sells a "Kit" that includes a bolt that is temporarily replaced with a screw-in grease fitting (and they include a tube of grease). Just make sure that you remove another bolt, so that the pressure has some place to relieve itself as you pump the grease in.
Plasticman
Old Apr 26, 2004 | 11:15 AM
JohnZ's Avatar
JohnZ
Default Re: Steering fluid question (Plasticman)
C2 Shop Manuals specify EP Chassis Grease :thumbs:
Old Apr 26, 2004 | 10:23 PM
vettejoel's Avatar
vettejoel
Thanks :thumbs:
To Steering fluid question
