Alignment in Ct
Old May 8, 2004 | 10:41 PM
w1ctc's Avatar
w1ctc
Default Alignment in Ct
Just got done with a rear suspension rebuild and need a good shop for
a 4 wheel alignment in the New Haven, Ct area. Any suggestions?
Old May 9, 2004 | 12:57 AM
Larry P's Avatar
Larry P
Default Re: Alignment in Ct (w1ctc)
If you can't find a shop that does them often, find a reputable shop and take your ST-12. It has the information they need.
Larry
Old May 11, 2004 | 12:37 AM
tuxedo's Avatar
tuxedo
Default Re: Alignment in Ct (Larry P)
Also take the shims for the front and back. They may have the fronts but probably not the back shims. Stay with the car the whole time at the shop and try to drive it on and off the Hunter alignment machine. I won't bore you with my three day alignment saga at the shop and a bent front cross member plate. Just make sure they are really reputable and know what they are doing. But the shop I used was reputable and said they knew what they were doing and could do this old car " no problem". So be very careful.
Old May 14, 2004 | 05:21 AM
65coupe's Avatar
65coupe
Try "Corvette Center" 184 Day St. in Newington. 953-2994
To Alignment in Ct
