Coil Bracket
Old May 10, 2004 | 02:48 PM
65stinger's Avatar
65stinger
Default Coil Bracket
As most of you guys can tell, I'm smack dab in the middle of reworking this car. I have many small questions that keep popping up I have no answer to.....I have the 327/365 no air. What side does the coil bracket go on, passenger or drivers side?
Old May 10, 2004 | 03:08 PM
ctjackster's Avatar
ctjackster
Default Re: Coil Bracket (65stinger)
P-side, making it hard to get a wrench on the distrib hold down bolt :rolleyes:
since the coil bracket supports the ignition shielding it is shown in this LIC catalog page (pretty useful for those of us asking "where the F-- does this go?") for ignition shielding:
LIC catalog Section 30
you will need the other ign shielding brackets correctly oriented too if you would like to reinstall the shielding some day
[Modified by ctjackster, 3:13 PM 5/10/2004]
[Modified by ctjackster, 3:14 PM 5/10/2004]
Old May 11, 2004 | 09:01 AM
65stinger's Avatar
65stinger
Default Re: Coil Bracket (ctjackster)
That proposes another question. What if I have the radio delete option. Can it go on either side?
Old May 11, 2004 | 09:08 AM
ctjackster's Avatar
ctjackster
moving one thing begets more issues. Your wire harness (to the coil, anyway) will be disturbed, not too much extra length built in. I also am not sure if the stock coil bracket can be "flipped" around, without persuasion anyway. finally, your throttle cable might be in the way.
Old May 11, 2004 | 09:53 AM
65stinger's Avatar
65stinger
There I go again....not thinking clearly. I didn't think about the throttle linkage and other crap on that side. Forgive me, but I still don't have the body back on the frame yet. So It's not clear to me the things that might get in the way. I do plan on sitting the body back on this weekend.
thanks a bunch
To Coil Bracket
