Holley Numbers
Old May 10, 2004 | 04:24 PM
autocolor's Avatar
autocolor
Default Holley Numbers
Can anybody please identify the following numbers from the air horn of this Holley Carb ?
1850-3 2869
TIA
Mike .
Old May 10, 2004 | 11:55 PM
waynec's Avatar
waynec
Default Re: Holley Numbers (autocolor)
[Modified by waynec, 9:01 PM 5/10/2004]
Old May 11, 2004 | 12:01 AM
waynec's Avatar
waynec
The carb is an 1850 (model family is 4160), a common aftermarket 600cfm 4-bbl. I think the "2869" is most likely a date code: day 286 of year 1979. It is an inexpensive version of a 4150 model, the main difference being that the 4160 has a drilled metering plate rather than a metering block with replaceable fuel jets for easier tuning to fit your application... the 4160 can be upgraded to a 4150 by making those replacements.
Starting in 1964, many C2 and C3 Corvettes came with either 4150 or 4160 Holley carbs, but not the 1850.
Old May 11, 2004 | 12:44 AM
Plasticman's Avatar
Plasticman
Default Re: Holley Numbers (waynec)
The 1850 was originally used on 1959 Lincoln (Ford) 430 engine. It has been updated by Holley and is sold as a generic 600cfm low cost street carb (I think the Holley version is a manual choke - but you can purchase a separate Electric choke as well).
Plasticman
To Holley Numbers
