Help! Unstable Idle
Old Jun 26, 2004 | 05:26 PM
1quik6's Avatar
1quik6
Default Help! Unstable Idle
Starting to do some PM to my 1964 327/365 Stingray. Used JonhZ's procedure on setting the valve lash. Also put in some new Autolite plugs gapped at .045. New air cleaner & had the Holley 600cfm carb. rebuilt last week. Timing is around 12 deg. advanced.- Seems that the idle is very unstable, if I set it at 900rpm its fine till the first time I rev it up- it seems to rev back down to around 1400rpm & stabilizes at that rpm. If I adjust the carb.idle adjust.screw out it will idle down to 900 rpm but after awhile it seems that it will idle very low around 500 rpm. Then I adjust the idle back up to 900 & gas it and then the cycle begins again. I checked the throttle linkage & its not in a bind- whatsoever. The manual choke has been wired open & the vaccum secondaries seem to be closed. Could the dual point mallory dist. cause this? I checked the dwell today & with only the ignition on it was at about 30 deg. but if I turned the car on it was reading about 5 deg & the car would idle very low & eventually would cut off. Running out of ideas. Any suggestions?
[Modified by 1quik6, 10:27 PM 6/26/2004]
[Modified by 1quik6, 10:29 PM 6/26/2004]
[Modified by 1quik6, 11:54 PM 6/26/2004]
Old Jun 26, 2004 | 05:51 PM
panchop's Avatar
panchop
Default Re: Help! Unstable Idle (1quik6)
not corvette but if one of my old harleys was doing that (and they have) i would look for air leaking into the intake manifold.
Old Jun 26, 2004 | 05:59 PM
JohnZ's Avatar
JohnZ
Gap your plugs at .035", not .045". Your idle is unstable because you don't have a functioning vacuum advance system that's fully deployed at idle; you're idling "on the curve" of the centrifugal advance system in the distributor. Trash the non-vacuum advance Mallory dual-point distributor (lots of people on eBay who don't know any better will want it), and replace it with a stock Delco vacuum advance distributor, with an Echlin #VC-1810 vacuum advance can ($10 at NAPA), connected to full manifold vacuum. End of problem.
Old Jun 26, 2004 | 06:08 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
also make sure the advance weights in the distributor are returning all the way. sticking advance weights will cause your problem. this even happens in GM distributors
Old Jun 26, 2004 | 09:22 PM
vettefool's Avatar
vettefool
Default Re: Help! Unstable Idle (clem zahrobsky)
I had this same problem on my 66 350hp after engine rebuild with stock gm cam. found an article in ncrs corvette restorer mag. that suggested a vacuum advance unit from bumper to bumper auto parts chain. after installation problem solved. I'm sure other chains sell the same or similar unit.
Old Jun 27, 2004 | 02:11 AM
1quik6's Avatar
1quik6
Default Re: Help! Unstable Idle (vettefool)
The dual points are on the top plate & the springs seem to be under them. Is it possible to take the top plate off & maybe clean & lubricate the weights & springs? Does the non-vaccum dist.'s have an advantage over the vaccum dist's.? HP?
Thanks In Advance
1QUIK6
Old Jun 27, 2004 | 07:45 AM
clem zahrobsky
Cruise-In I Veteran
i am sure you can remove the top plate and get to the springs and weights. a vacuum advance distributor will give you much better gas milage than the one you have and the performance will be the same
To Help! Unstable Idle
