Engine harness problem
Old Jun 28, 2004 | 03:56 AM
Pompe's Avatar
Pompe
6th Gear
Default Engine harness problem
I´ve bought a new harness for my -65. The problem is that the harness seems to be done as if the generator and relayboxes should be placed on the right hand side of the car. We have three other cars with original wiring, and the new harness doesn´t match any of the others (-66,-66,-67).
Any ideas? I dont want to start cutting on the new harness, but maybe that is the only answer.
Old Jun 28, 2004 | 05:05 AM
67435animal's Avatar
67435animal
Default Re: Engine harness problem (Pompe)
It may be the wrong harness. Does it match exactly the original harness? If not, return it. For a quality harness, check M&H at http://www.wiringharness.com. Best harnesses out there that I have seen.
Bob
Old Jun 28, 2004 | 06:15 AM
aworks's Avatar
aworks
65 small block cars with no AC have the alt. and reg. on the right side. Big block cars and all cars with AC are on the left. 66-67 are all on the left. So your harness is correct.
Old Jun 28, 2004 | 06:25 AM
Pompe's Avatar
Pompe
6th Gear
Default Re: Engine harness problem (aworks)
Thanks for the answers.
Well, the harness might be correct if i had a -65 smallblock, but i have a bigblock...
I live in Sweden, and it would take to long to return the harness and recieve a new one(short summer in sweden).
It seems that my only option is to start cutting in the harness, unless anyone else has some input.
Old Jun 28, 2004 | 06:27 AM
aworks's Avatar
aworks
Yep your right you have no choice.
Old Jun 28, 2004 | 01:03 PM
JohnZ's Avatar
JohnZ
You have the wrong harness for your car; it's a lot of work to convert all the circuits to the correct driver's side configuration, but that's your call.
To Engine harness problem
