radiator help needed
Old Jun 28, 2004 | 01:25 PM
crw41's Avatar
crw41
Default radiator help needed
I have a 66 coupe with AC. I removed the radiator today. I had to loosen the fan and eventually got the radiator and shroud out, but it was a very tight squeez. I am not looking forward to putting it back in. Is there a way to loosen the AC condensor to move it forward somehow. In other words, what would be the easiest way to get it back in. It seems that trying to drop the radiator and shroud in one piece gets hung up between the upper control arm and the the suport that holds the AC condenser unit.
Old Jun 28, 2004 | 08:20 PM
wombvette's Avatar
wombvette
Default Re: radiator help needed (crw41)
Remove the hood. Remove the two upper bolts on the radiator support and loosen the lower mounts. Rock the suport frontwards.
