sidepipe crossover
Old Jul 4, 2004 | 01:28 AM
panchop's Avatar
panchop
Default sidepipe crossover
anyone figure out a clean way to put a crossover pipe on a set of hooker sidepipe headers. something that won't kill the ground clearence
Old Jul 6, 2004 | 04:57 PM
Aussi-66's Avatar
Aussi-66
Default Re: sidepipe crossover (panchop)
I have done a crossover on my side piped 327, it works very well and isnt in the way. I will take a photo or two and post them for you in the next couple of days.
Old Jul 6, 2004 | 10:16 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: sidepipe crossover (Aussi-66)
i like to see pics also.
Old Jul 7, 2004 | 12:54 AM
panchop's Avatar
panchop
Default Re: sidepipe crossover (patsnitrovette)
i would very much like to see those.
Old Jul 7, 2004 | 07:19 PM
Aussi-66's Avatar
Aussi-66
Hi Guys
here are the images of the sidepipe setup that I promised. I fitted a hotdog muffler in each side to keep the local law happy, system sound and works very well. [IMG][/http://www.photohost.org/gallery/http://www.photohost.org/gallery/showphoto.php/photo/56961/password/0/sort/1/cat/last1/page/2showphoto.php/photo/56966/password/0/sort/1/cat/last1/page/1IMG] [IMG][/IMG]
Old Jul 7, 2004 | 07:47 PM
Aussi-66's Avatar
Aussi-66
Had trouble getting the pics to attach to posting, here is the 2nd try.
[img]www.photohost.org/gallery/data/592/4814DSC00697-med.JPG[/img] [img]www.photohost.org/gallery/data/592/4814DSC00694-med.JPG[/img] [img]www.photohost.org/gallery/data/592/4814DSC00693-med.JPG[/img]
Old Jul 7, 2004 | 07:54 PM
Aussi-66's Avatar
Aussi-66
Photo attachment attempts were a complete disaster. Go to photohost.org chev corvette and look in the last day or 14 days you will find the photos there. sorry for the inconvienience
Old Jul 9, 2004 | 07:12 AM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
To get your photos to post, you need to include the "http://" with the rest of the URL.
Here's your pics:
Old Jul 11, 2004 | 10:08 PM
PatsLs1vette
i like it,nice job.
Old Jul 14, 2004 | 12:29 AM
Mecom Racer's Avatar
Mecom Racer
Someone please refresh my memory...
How does the crossover help?
Are there any disadvantages?
Old Jul 14, 2004 | 12:42 PM
JohnZ's Avatar
JohnZ
The following elegant explanation was posted on the NCRS Board about three years ago by Duke Williams (SWCDuke), and I'm sure he won't mind my sharing it here, and he may want to comment further; I've paraphrased it somewhat.
Without getting into a lot of gory detail, each bank on a Detroit V-8 has uneven firing intervals (0-180-90-270) due to the cruciform crank (as opposed to the "flat" crank used in IRL/Champ Car engines and Ferrari V-8's, which have even firing intervals on each bank). With uneven firing on each bank, the two cylinders that are 90 degrees out of phase are problematic because as the lead cylinder is in the final scavenging phase as its piston passes 90 degrees BTDC on the exhaust stroke, the trailing cylinder blows down, and that pressure wave disrupts scavenging on the lead cylinder.
A balance pipe helps helps dissipate this pressure wave by providing two exit paths - through both exhaust pipes rather than just one. This reduces the intensity of the pressure wave, which reduces noise and lessens the interference with the lead cylinder exhaust stroke, which can enhance torque (and produce a more pleasing exhaust note). This is all highly theoretical, and is subject to many other variables; on a street-driven car, it mostly just makes it sound better.
Old Jul 20, 2004 | 07:25 PM
Mecom Racer
I wonder if that would that be the same for an LS1 or LS6. They have a different firing order than the old small blocks.
To sidepipe crossover
