Ignition key
Old Jul 14, 2004 | 06:41 AM
Pompe's Avatar
Pompe
6th Gear
Default Ignition key
Hi
How do i open the ignition key lock to change to another one with keys?
The car is a -65 bigblock.
Regards
Old Jul 14, 2004 | 07:38 AM
62fuelie's Avatar
62fuelie
First, you need the key to the lock, and a medium size paper clip. Insert the key in the lock and the clip in the small hole to the right of the key. With t he key al the way to the left, you can push on the paper clip and feel a small spring loaded plunger. Push on the plunger until you can turn the key a bit farther to the left and the lock assy will pop out.
Old Jul 15, 2004 | 04:17 AM
Pompe's Avatar
Pompe
6th Gear
Default What key
Well, as i said, i want to change to a lock with keys....
Since i dont have a key to the old lock, your answer, good as it may be, is of no use to me ;-)
Any other suggestions?
Old Jul 15, 2004 | 09:06 PM
JohnZ's Avatar
JohnZ
Time to call a locksmith to "pick" the lock; the key cylinder won't come out (and you can't remove the switch from the cluster without removing the key cylinder) without either the key or the talents of a locksmith.
To Ignition key
