Upper Shift Point with Powerglide?
Old Jul 14, 2004 | 05:05 PM
Paul L's Avatar
Paul L
Default Upper Shift Point with Powerglide?
Under WOT what rpm and/or speed should a 1967 327/300 shift into drive? Car is stock.
Old Jul 14, 2004 | 06:19 PM
firemist1's Avatar
firemist1
Upper shift point is controlled by the governor in the transmission and it shifts at 55 miles per hour.
Old Jul 14, 2004 | 08:03 PM
Paul L's Avatar
Paul L
That sounds right. Do you mean the vacuum modulator?
Old Jul 15, 2004 | 12:51 AM
firemist1's Avatar
firemist1
No. The modulator comes into play for all other part throttle shifts. The governor is the circular piece on the passenger side of the transmission. For Corvettes, the set point is 55 MPH. Corvette PG's are different than the garden variety PG's.
Old Jul 15, 2004 | 02:22 PM
Paul L's Avatar
Paul L
Thanks for that info. I had visions of making it a true "passing" gear at highway speed: shifting at 70mph. But I guess that is not doable.
To Upper Shift Point with Powerglide?
