Got stuck again!
Bob
If you have good spark and enough fuel that kind of puts it in the carb.
I've had Holleys with internal leaks, half of the fuel metering circuits go bad and on and on.
Put a Qjet on it
I would see if I could get another carb and bolt it on.
I've never heard of a carb float sticking closed.
If a fuel starvation problem only occurs at engine speeds near idle, then the root cause is probably in your carburetor idle circuit. Almost all fuel is supplied through the metering block idle passages at engine speeds below 1,000 rpm. The idle circuit stills supplies most fuel up to about 2,000 rpm.
I'm guessing you periodically have something stuck in one of these passages. When it washes down far enough to get jammed around one of the idle mixture screws, your engine dies at idle. However, the engine will run if you supply gas through the accelerator pump system or rev the engine fast enough to use the primary jets.
As far as the rude comments and obscene gestures instead of offers of help, you may have to move to eliminate that problem.
Almost certaihnly a carb problem in the idle circuit. It should be pretty easily fixable without carb replacement, assuming the carb is in good general overall condition.
was empty. Pumping the accelerator would keep it running
for a awile and them die totally. By the time I got out of the car
to look the pump would be squirting again. One more test I
did today was pump some gas into a clean container. Found
dirt that was getting though the crap glass filter. The junk
would have to get past the bronze filter on the carb inlet
also. I'll put on a better filter and clean out the tank. It will
be awile before I trust this thing again. Kinda takes the fun out of it.
